audionewbi
- Jan 24, 2010
what optical cable is this?
But the entire purpose of HUGO is for use on the go. Once again the battery issue is something that is one of those rare theoritical even that have no significant practical basis.
I have been looking into the problems of RF interference with Hugo and BT.
When this problem was first reported, I re-checked my Hugo with a Sennheiser BTD 300 connected to my Win 8 machine. Running in DAC mode, and fully portable mode, it worked perfectly no problems, absolutely no noise.
So I asked Matt at Chord to re-run his tests on BT, specifically looking for noise with headphones, with current production units. Absolutely no problems with iPhone, IPad and Samsung phone BT sources.
By saying this, I am not trying to play down this issue, but in able to fix an issue we must be able to see it being demonstrated in mine or Chord's labs.
Upon talking to Matt, the thinking is that the 2.4 GHz BT signal is being amplitude modulated (AM) by the source transmitter with noise on it's local power supply. This AM modulation is being picked up by the headphone cable and either demodulated back within Hugo, or being demodulated in the headphone directly. If Hugo is close to the source then the problem gets better, this is due to the BT transmitting with lower power, thus reducing the feed into headphone cables. The reason that the issue is variable is that it depends upon the quality of the BT TX., and the headphone/cable RF characteristics.
An interesting post from Kantana confirms this - using an attenuator solves the issue. This would decouple the RF back into Hugo, or it works by decoupling the low RF OP impedance of Hugo from the headphone, thus reducing headphone pick-up directly.
Rather than using attenuators directly, it would be better if you experience this problem, to try cylindrical ferrite cores. You could try the solid cores, and push the headphone plug through the centre, then loop it over the core, then back through the centre. Or you can buy cores that have split sections, and you just open them up and place the cable in the centre, and close it down. I suspect this might solve the problems. Please give this a try and feed back the results.
I just connected the Hugo to my iPhone via Bluetooth. Other than trying to figure out the four digit code there were no issues. Via onkyo hi fi player I streamed all types of music from flac to dsd. The light stayed red on Hugo so that shows lowest Rez. No noise or issues. Sounds fine to me. No buzz or hiss or background noise. So here is one Hugo unit that sounds just fine. Not as good as via HD USB or coax but for BT pretty darn good. No issues.
My Note 3 is APtX and still you get the interference. I bought a Bluetooth transmitter that support Aptx and still you get the same interference.
Maybe so, but at some point we are going to get a Hugo + player all in one...
Hugo is up for sale at Custom Cable for £1,199 or about $2K. Original Chassis only. Hard to resist!
Are there any other chassis? What's original chassis?
