turbomustang84
- Mar 13, 2010
What Headphone Amplifier are you guys using with the Qutest ?
Check out our signatures!What Headphone Amplifier are you guys using with the Qutest ?
Auralic Taurus MKII. High power, high resolution, very spacious with excellent depth, very transparent. Doing all of this without being cold or boring. Completely allows Qutest's brilliance to shine through.What Headphone Amplifier are you guys using with the Qutest ?
With 2 amps actually in the same time:
1) Solid State: Beyerdynamic A2
2) Tube: Feliks Audio Elise MK2
Because A2 has a great feature of Input 1 is hard looped to Output and works even if A2 is turned off, I "cascaded" both amps and I listen to each one depending on mood, to both or even to 3 headphones at the same time. What else can you dream of? And yes, Qutest is making them sound great.
That sounds like a great idea! Are you noticing no effect on sq when you have both on at same time ?
My Icon has a loop out that works even when it is off but I never tried to use it.
So if I m getting this right you re taking the signal from Qutest in to the line in of your amo and then connecting the loop out to the second amp ?
It sure isA simple JDS Labs Atom. I have a THX 789 on order. Honestly the Atom is pretty spectacular.
LP is objectively the better one of both. Also Lyr has some freak occurrences of frying headphones, I'd err on the side of cautionLyr 3 or LP
THX AAA789 will be delivered in May
