Hi Rob,
I recently bought this qutest dac, when I tried to feed it with some 768KHz PCM or DSD512 audio stream output from HQplayer, I always heard very serious distortion, glitches, pure white noise on one channel(usually right) or audible white noise in the music background.
Could you tell me what might cause the problem?
I did some tests, hope they may be helpful:
1. when I play audio at 384Khz or DSD256, qutest has no problem.
2. mojo has the same issue when playing at highest possible sample rate(ex. 768KHz or DSD256 for mojo).
2qute seems OK at DSD128 and PCM 384Khz.
3. I tried qutest with the stock cable and a very short USB cable I have, didn't see significant improvement.
4. I thought it might be my computer that has performance issue, but I tried it with other DAC(RME adi2 dac), it is capable of feeding DSD256 or PCM 768KHz smoothly. Issue happens only when chord product is used.
I know you don't recommend people using any upsampling software with chord dac, but I just want to do a comparison of 'qutest playing hqplayer dsd512 vs qutest playing bit-perfect audio' in order to valid your point.
Thank you,
C
