It appears you mean that 16 ferrites are "ugly and cumbersome looking"
Well think of it like this: ferrite cores are a filter for the problems caused by all the equipment that processes the digital signal, transmitted along the cable that plugs into DAVE and for the tendency of the cable, itself, to act as an antenna.
We already know that each piece of equipment that processes the digital signal is failing to do so cleanly, otherwise you wouldn't hear improvements from filtering closer to DAVE. Ferrites are actually the strongest filter you can use (if you use enough).
They are also extremely easy to buy, easy to use and cheap. So the best filtering is the simplest and cheapest. That sounds like the elegant solution to me...
I suppose you could find a cloth braid type cover to wrap the entire cable if you thought it would look better as an "audiophile hose"! And it would be heavy, too.
At worst, it just means you'll need to use more ferrites than expected to hear any change. When you hear a change, it is by definition an improvement and proof that the other equipment has failed at being "clean".
Now playing: Anouar Brahem - Uns
