Jawed
- Dec 7, 2014
You should apply the ferrites to the digital signal cable that connects to DAVE, placing them on the cable close to DAVE. DAVE contains the analogue circuit that is affected by RF noise, so the filtering should be as close to DAVE as possible.
A clear indication it's better is that you'll hear metal, percussive, sounds such as cymbals, tambourines and bells sound faster and clearer. The reduction in distortion on those sounds will also make them less "spiky" sounding, which initially appears as if the treble has been rolled off. But it hasn't, it's simply a faster, cleaner sound. You'll hear the individual metallic sounds much more easily.
This is also the reason you'll hear less errant sibilance: speed and refinement in treble turns a "messy sibilant" into a cleaner sound that is more natural.
In general everything sounds faster and extra detail is revealed instead of being covered up by a smeary/spiky mess. You'll also notice an increase in bass power and groove in the music will be more obvious. etc. The effect is top-to-bottom sonically and musically.
The right place for ferrites is close to DAVE. Everything else you do to optimise noise within the digital components is irrelevant if you filter the input to DAVE correctly with ferrites. If you can hear changes because of tweaks to your digital components, you need to use more ferrites on the cable that connects to DAVE.
Now playing: Hazel O'Connor - Will You?
