JaZZ
I know nothing. I'm still extrapolating from the 1 million taps experience, which was a surprise after all. So I wouldn't be surprised if doubling the tap count would surprise us again.
During his university days, Rob Watts developed his hypothesis that a 16 bit data input, would need 1 mill taps to convert this back into an analogue waveform, that the human ear/brain could not distinguish from the original.
Also does anyone know if the future Chord digital amp will only work with Dave, and if so what function will Dave perform in that set-up, if the user also has a Blu2? I guess no one knows yet just trying to understand if there is any point to wait for the Digital amp if i go for Hugo 2. Thank you
I'm not sure if these will serve the purpose with Blu2. Download the manual for the original Blu. It has word clock input and output for pro applications and dual BNC outputs for use with DACs. Blu also does not come with 75 ohm cables so I assume that you will have to have a pair on hand on when setting up the Blu2.
I agree, however, that you will not need to have the most expensive BNC cables to get Blu2 to work with Dave. This does not discount the possibility that higher end cables may potentially give you a detectable performance boost. I suspect that Rob may eventually weigh in on this question and that Roy will eventually post on his adventures with different BNC cables. Speaking for myself, unless HFC comes out with a Reveal BNC to BNC cable, I will probably get a pair of Atlas Mavros Ultra cables and call it a day.
As a very happy Hugo owner (that I use at home only), I would still love to have galvanically isolated USB for the Hugo 2 as requested by so many.
A low-pass "perfect sinc" filter with 1 million taps will produce a different result depending upon whether you feed it 2x, 4x, 8x or 16x (etc.) sample rate data. The frequency response will vary, as will the rejection of frequencies above Nyquist. The coefficients have to vary depending upon the ratio of cut-off frequency to the upsample rate and the count of original samples that are used to compute each new sample varies with the upsampling rate, for a given tap length.
I'm unclear on what sample rate Rob was thinking of when he did his calculation, originally.
My understanding is that for a given tap length, e.g. the 164,000 taps in DAVE, Rob heard differences depending upon the upsample rate. Eventually he rejected 8x upsampling for the first stage WTA filter in DAVE (it sounded too soft) and chose 16x instead.
Also, M Scaler uses the WTA algorithm, which, as far as I can tell, means it is not the pure sinc function running with such high precision due to sufficient taps, that there is no residual error in the resulting analogue waveform, which is what Rob apparently hypothesised originally (he hadn't developed WTA back then, of course). In this case I think it's reasonable to assume that the WTA coefficients are not the same as the coefficients produced by sinc. That appears to imply that the sound of M Scaler is not the same as it would be if sinc coefficients were used instead.
The reason to use WTA is "transient accuracy", implying high-frequency, high amplitude signals are not softened by the low-pass filter (DAVE's transient speed is amazing, after all!). In theory M Scaler with WTA coefficients was chosen because it sounds better than the coefficients derived purely from sinc. If that's the case, then it would seem it already contradicts the idea that 1 million taps is enough, since the original idea was 1 million taps based solely upon sinc.
So, these two reasons combined are why I doubt a million taps at 16x upsampling is the limit for audible improvements.
Now playing: Shelly Manne [At the Blackhawk] - Poinciana
HFC Reveal Digital RCAs will soon be available with BNC terminations available upon request. The Reveal will have a performance level that is better than HFC's CT-1 and just below CT-1E (but closer to CT-1E than CT-1) and will cost less than CT-1. The CT-1s and CT-1Es will be phased out in favor of the Reveal and will be priced less than the CT-1. Anticipated price will be $700 USD for 1m ($1,400 for a set of 2). In HFC's internal testing, their new entry level Reveal line is outperforming Nordost Odins and HFC is willing to guarantee it or your money back. I would expect that they will easily outperform the Atlas Mavros Ultra.
As with all digital coax cables, to avoid the negative impact of reflections, the ideal length of these cables will be 1.25m to 1.5m. This is one of those situations where shorter does not mean better.
Thanks Roy. I guess now I know which cables I'm going to buy. Will probably get a Reveal power cable to go with it. The Atlas Mavros at approximately 520 USD per pair are roughly a third the price of the Reveal BNCs. Of course, when you figure in the fact that my entire system is connected with HFC cables there's system synergy that makes for an even larger improvement.
Yes life has been extremely busy - last week was finishing production code for Blu 2 (tested and delivered to Chord) and finishing Davina PCB (just front panel left to do).
I have just arrived in Japan with John, picking up another award for Dave and next week I plan to do a full posting about Hugo 2 on my blog showing all the slides in full plus adding some more comments.
But just to clarify - the Hugo 256 FS filter is identical to Dave's - and with the M scaler and Dave the HF filter option is best off as I have innately improved the stop-band rejection - so noise isn't needed to be filtered away because it's already gone. That was why it was odd that 44.1 sounded better overall with the filter on, as my expectation was for no change as rejection of out of band noise was already 130 dB, and in the critical areas (around multiples of the sample rate) with the most noise present, was about 150 dB rejection.
Rob
When you design a low pass filter, the upsampling rate (8x or 16x, say) affects the design, and the sound of the filter. 8x upsampling wasn't high enough for 164,000 taps in DAVE. Perhaps 16x isn't enough for 1 million?
When you've chosen the upsampling rate and the number of taps, the choice of algorithm (e.g. WTA or sinc) affects the sound. The original theory is that sinc sounds best when you have enough taps. If you have less than enough taps, then you use WTA (and there are other choices, which Rob has rejected as inferior) to apply a correction for the error. M Scaler uses WTA, implying that it sounds different from sinc. This might imply that sinc is not accurate at 1 million taps.
So, both of those ideas make me suspect Rob's going to be busy exploring more than 1 million taps.
Now playing: Calvin Party - Repetition No. 2
