CHORD ELECTRONICS DAVE
- Thread starter magiccabbage
- Tags
- chord-dave
801evan
CD transport.what is cdt?
Ards
- Jul 22, 2010
There's clearly a race condition here. All things being equal, high resolution should sound better than 44.1. Problems with 44.1 are well understood; problems that higher resolutions solve. But when things aren't equal (eg degradation in either delivery chain) then one can leapfrog the other.End of the day, CDT with a good psu will trump Hi-Res file.
A local source, such as a CD transport is a great sanity check for the streaming side of any system. If the CD sounds better, it suggests there's more work to be done on the streaming side.
Triode User
Member of the Trade: WAVE High Fidelity
Yes to this and Rob Watts always suggested using the Blu mk2 as a test against streamed or ripped files to judge how good that system was against a low noise CD player.A local source, such as a CD transport is a great sanity check for the streaming side of any system. If the CD sounds better, it suggests there's more work to be done on the streaming side.
ZappaMan
Are there any suggestions for “cheap” CD player components, and cheap meaning, as cheap as possible. Would a £50 Walkman style CD player on batteries be good?Yes to this and Rob Watts always suggested using the Blu mk2 as a test against streamed or ripped files to judge how good that system was against a low noise CD player.
Cambridge audio cxc seems good.
801evan
No. Poor clock. And reliance on battery is also bad.Are there any suggestions for “cheap” CD player components, and cheap meaning, as cheap as possible. Would a £50 Walkman style CD player on batteries be good?
Yes! Now we're talking! Farad Super 3's installed in to DAVE. Very enjoyable job it was too!
What does it sound like? Absolutely awesome! I was toying with the idea of EQ'ing my LCD-5's but no need... everything is now brilliant and and can only get better after several hundred hours of use. The synergy of my audio equipment must also have something to do with it as well. It's exactly what I want to hear without any overbearing Trebles or Bass. Spot on for for mid range as well... it's as though it was meant to be.... in my system anyway.... and for my hearing. Can't believe my luck with the coincidental upgrade of this power supply and the 'gelling' of my LCD-5's. Perfect.
The install was a breeze. Removal and replacement of the internals proved to be simple. Also gave me the chance to remove some dust under the DAVE's glass display which was there from new! Working methodically I don't think anyone will have a problem with this upgrade installation of which I highly recommend DAVE owners to obtain. No doubt owners of the SJ ARC6 DC4 will state its superior.... probably is.... but for my money... which doesn't stretch as far as the ARC6.... this is a stunner of an upgrade!
Good job mateYes! Now we're talking! Farad Super 3's installed in to DAVE. Very enjoyable job it was too!
The install was a breeze. Removal and replacement of the internals proved to be simple. Also gave me the chance to remove some dust under the DAVE's glass display which was there from new! Working methodically I don't think anyone will have a problem with this upgrade installation of which I highly recommend DAVE owners to obtain. No doubt owners of the SJ ARC6 will DC4 will state its superior.... probably is.... but for my money... which doesn't stretch as far as the ARC6.... this is a stunner of an upgrade!
![Thumbs up: medium-light skin tone :thumbsup_tone2: 👍🏼](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f44d-1f3fc.png)
![OK hand: medium-light skin tone :ok_hand_tone2: 👌🏼](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f44c-1f3fc.png)
Also good to see you don't have any bad caps there!
Excelent stuff! Congrats on the install and thank you for the step by step pictures.Yes! Now we're talking! Farad Super 3's installed in to DAVE. Very enjoyable job it was too!
Paul Bjernklo
CD Transport quality makes a significant difference. For “budget” CDTs, Audiolab 6000CDT at £400 seems hard to beat and I have read on par or better than Cambridge Audio CXC at around £549 in the UK. There are of course better but more expensive ones, but based on hi-fi reviews these are the top proper “budget” contenders I have seen so would recommend to have a listen to either if available in your countryAre there any suggestions for “cheap” CD player components, and cheap meaning, as cheap as possible. Would a £50 Walkman style CD player on batteries be good?
Triode User
I am pleased you are enjoying the LPS. As I have said before, my only experience is comparing the Farad with the Qutest and then it was pretty much on a par with the Sean Jacobs DC3 which is possibly a fair bit cheaper. The Dc4 was quite an advance over the Farad but I did not compare the ARC6 which is some way beyond the DC4.No doubt owners of the SJ ARC6 DC4 will state its superior.... probably is.... but for my money... which doesn't stretch as far as the ARC6.... this is a stunner of an upgrade!
One day we will all be able to get in the same room with this kit and have some fun comparing it. Until then, keep enjoying the music.
![Grinning face with smiling eyes :smile: 😄](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f604.png)
nwavesailor
- Nov 14, 2009
I am not questioning that the Farad is a very nice step up for the Dave.Yes! Now we're talking! Farad Super 3's installed in to DAVE. Very enjoyable job it was too!
What I am not excited about is adding 3 more boxes and cords to my 24" x 24" table with the Dave, M Scaler, Bigger Ben or Envy amp. I understand the different voltages and seperate PS just not wanting a stack of 3 more chassis.
Reactcore
![Thumbs up :thumbsup: 👍](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f44d.png)
Im still patiently awaiting the arrival of the components to make my supercap precharger
It will test my theory that its the SJ and Farad current reserves in their caps that give the performance boost. Not so much net RF filtering
As someone who uses a mains filter + a power regenerator plugged into it and has seen massive performance gains from them, both in separation, and cumulatively, I would disagree. That said, I'm sure the extra current reserves would help as well.It will test my theory that its the SJ and Farad current reserves in their caps that give the performance boost. Not so much net RF filtering
Same boat, I care what it sounds like up to a point, after that, I care what it looks like more. Did you get to buy the Envy amp? I'm also considering it. Curious what it's like with DaveI am not questioning that the Farad is a very nice step up for the Dave.
Total: 33 (members: 0, guests: 33)
