Jul 6, 2015 at 12:59 PM Post #167 of 27,088
I think the Chord maybe have designed a new amp classification like a hybrid btw Class D and Class A-B and can be controlled by DAVEś new special digital outputs, where the D/A conversation happends after the amplification for a more exakt amplification in the digital domain. So i think DAVE acts as a Word Clock and signal source for the amps, thats why its to outlets.
But its just speculation
Are we closer to the target JaZZ ?;)
Jul 6, 2015 at 1:08 PM Post #168 of 27,088
I have no further idea, I give up. Mysteries are fun, too.
Jul 6, 2015 at 1:59 PM Post #169 of 27,088
My main concern about the Dave compared to Hugo is that it has an internal switching power supply. Compared to the Hugo which is battery powered or with an external supply, it might introduce EM noise... as opposed to an isolated battery which is what I think made the Hugo such a success.
Jul 6, 2015 at 2:10 PM Post #170 of 27,088
An external PSU will have been a good thing. NO risk of EM noise and...even Allowing for (big)battery operation if needed.
Jul 6, 2015 at 2:11 PM Post #171 of 27,088
Chord knows how to make a proper SMPS very well so that noise should not be an issue. Other high end companies like Jeff Rowland also make use of SMPSs of their own design and they are not noisy by any means. A properly designed SMPS can outperform a conventional linear supply, and should not be categorized together with cheaply made SMPSs.
Jul 6, 2015 at 2:23 PM Post #172 of 27,088
Dave has such a wide OP level and ultra low noise, the gain of the power amp is unimportant.
Dave is SE as that's the best for SQ; but to do so is much harder, as differential gives measured benefits that hides SQ problems. Going SE means that you no longer hide the problems.
Rob
Rob, I have a Hugo which is wonderful driving active ATCs. I made up some suitable phono to XLR cables. I am thinking of upgrading to a Hugo TT, one of the reasons being the balanced outs on the TT. Are you are saying that I should still drive my ATCs from the phono outs of the TT rather than the balanced outs?
Jul 6, 2015 at 2:23 PM Post #173 of 27,088
According to Rob Watts (posted in the «Hugo» thread) Chord has managed to maintain the same noise-free power supply as from the Hugo's and TT's battery – and the 2Cute seems to prove that. I absolutely trust Rob on this – he's a perfectionist with excellent hearing, not just a data fetishist.
Jul 6, 2015 at 5:04 PM Post #174 of 27,088
Is it ATC SCM50 SLA or what ATC do you use?
Jul 8, 2015 at 7:57 AM Post #175 of 27,088
I think the new digital amp will have a pulse array dac, but will take the output of the filter in DAVE
The pulse array dac isn't probaby that expensive, it is the FPGA that is the key element of the DAVE.
Jul 8, 2015 at 12:15 PM Post #176 of 27,088
Something like that.. Smart use of the FPGA filtering in the DAVE, and just extend the internal signal path to an external amp and achieve a perfect transport without any loss and make the final conversion in the AMP, thats clever.
Jul 8, 2015 at 7:46 PM Post #177 of 27,088
Rob, I have a question on Dave.
Can we still see the inside through the glass window? or the window is now an LCD screen and we can no longer see the inside?
I like the way Chord designs its products ... the users can see the inside and the LED lights on the boards and wondering if we can still do the same with Dave.
Jul 8, 2015 at 8:10 PM Post #178 of 27,088
My QBD76 HDSD Limited ED with DSD indicating Lavender LED lightning inkl Chord table alu bracket.
M
I can say to 99.9999999% unfortunately not, because of the LED or OLED display that CHORD will be using are most likley not a transparent display version, but even if it was, you could not see clearly true it, its going to blur out the chipset board.
Jul 9, 2015 at 6:14 AM Post #179 of 27,088
Sad, but true. The round display reminding of a porthole has its own charm, though.
  • Back
