Pictograms
Why would you not have both the poly and phone on the same wifi if that’s the case? I don’t understand the problemBut I can't also connect to a real wifi simultaneously, so it's a problem,
What a joke
What a joke
The poly can create a hotspot that your phone can join so you can access the music files or you can make mpd playlists on the Poly sd card and access the playlists in the Gofigure app under quick play using Bluetooth
Your poly or phone can act as a hotspot and you can play music via the sd card.What if I'm on the go and want to use wifi public?
Mconnect is my goto.Of iPhone users most interested in SD card playback, is there a majority agreement on which app is best for poly?
iOS update to 13.3
Mconnect? Glider?
Thanks.
I didn’t realize there was no android equivalent. So you use your phone hot spot? As far as I know that wouldn’t consume any data accessing the poly SDHybrid mode did not work on Android when I explored this. Has it changed? There are wifi features not enabled to allow Android phones to fail over to mobile data. Why not? There was a post almost two years ago which informed the mode chord was to enable to make this work on Android. I gave up on using the poly Hotspot for outside usage and hope to have internet.
Yes I use my phone as the Hotspot but find the battery burn is big. Don't know why Chord can't fix this as the Samsung galaxy supports the same fail over to mobile data that Apple has but apparently there is a requirement for the poly to let Android that it can be preempted for internet access. CHORD PLEASE SUPPORT THIS ON ANDROID! Those of us who waited almost 1.5 years to get a basic working build deserve it! What a mess this has been.
iOS update to 13.3
Mconnect? Glider?
Thanks.
