Chord Electronics ☆ Poly ☆ (wireless & microSD module for Mojo) ☆★►USEFUL INFO on 1st PAGE!!◄★☆
- Thread starter Matt Bartlett
- Tags
- chord chord electronics mojo poly
melomania
- Apr 6, 2012
Yes, I use Mac and iPhone
Thank you very much for the return.
I tested MPDplayer now and it worked perfectly !!!!
Cool, it's the most basic approach but often works when all else fails!
melomania
- Apr 6, 2012
For any in the UK that are interested in jumping in, there''s an unbeatable deal at future shop right now. Builds on the current Mojo discount by adding a £50 off when you buy paired with a Poly. £750 instead of £900!
The guys there have been super helpful with me too.
AndrewOld
- Jun 19, 2014
Hmmm, think I’d just rather have a Mojo that you can connect to a phone without any problems. And you’d be able to play Amazon HD.
joshnor713
You have to configure Tidal in GoFigure and then in Hi-Fi Cast select Poly as a Renderer-mediaserver. Selecting Poly as a Justin Maggard Media Connect allows you to play off the micro SD.
Interesting, I'll give this a shot when I get the chance. Appreciate the screenshot. Cheers
- Aug 29, 2015
my poly has not worked since trying to update to 2.03. it won't even connect long enough to change setting. almost 72 hours
Matt Bartlett
Member of the Trade: Chord Electronics
Sorry to hear you are having a problem with your Poly. Have you tried emailing our support to get further assistance?
masterpfa
- Aug 29, 2015
hey Matt thanks forSorry to hear you are having a problem with your Poly. Have you tried emailing our support to get further assistance?
sergeywin1
Just purchased that track. It is 1.3GB in size in WAV format.
SUMMER VIBE
http://www.beaglekick.com/cn2/pg194.html
Poly plays it rather very well in Airplane GoFigure app. Needless to say the details are super crisp and separation is amazing.
masterpfa
SUMMER VIBE
Confession I have had this file on my Mojo/Poly for quite a few months, thought it only right to share
Yourmomm
- Jun 17, 2016
Problems out the box....
Hi, can anyone advise as I cant get this thing working, and chord FAQ are no good whatsoever.
Gofigure app is showing poly version: 1.0.26 and app version: 1.0 48. Gofigure shows poly is connected to my home wifi network, bluetooth switched off (although same problems exist with it turned on as well).
Problems:
1) gofigure app wouldnt let me enter date of purchase, so couldnt complete registration
2) wifi country in gofigure app "settings" says "uk", and this cannot be changed (I am in nz)
3) trying to enter "user" in gofigure app results in error message, telling me to update firmware
4) there is no "update firmware" button in gofigure device settings, and no, I'm not in hotspot mode.
First impressions of this thing (from long time mojo user) are NOT positive. I dont care about first two problems above, I just included them in case they were important to explain problems 3 and 4, which I DO care about, as the thing is unusable without resolving these.
Thanks for any advice.
Problems:
miketlse
- May 8, 2016
@Matt Bartlett are you able to help?Problems out the box....
Problems:
Yourmomm
- Jun 17, 2016
Thanks. Should have said that it IS working on bluetooth playback, but I didnt buy it for lossy bluetooth playback...I'm also aware of bluetooth prioritisation so turn bluetooth off when trying (unsuccessfully) to get wifi to work...
audi0nick128
Poly should automatically update , when connected to your network. Do you have a SD card inserted? You have to take out the SD card to update...maybe after updating your problems are solved.
Cheers
Cheers
Total: 80 (members: 0, guests: 80)
