Chord Electronics ☆ Poly ☆ (wireless & microSD module for Mojo) ☆★►USEFUL INFO on 1st PAGE!!◄★☆
Apr 8, 2019 at 11:04 AM Post #12,453 of 18,821
So fare so good:
Go Play updated to 2.0
Firmware at 1.0.41
Clicked on the update button and poly is now doing its traffic light thing. Waiting half an hour...….
Apr 8, 2019 at 11:05 AM Post #12,454 of 18,821
Should poly update to 1.0.41as soon as she is turned on and connected, or is it a case of, just whenever ?
As I have the gofigure update but firmware no flashy to .41
Poly will update to firmware V1.0.41 after it has been switched on and connected to the internet for around 10 minutes. However please be patient as there will be thousands of Polys all
potentially trying to update at the same time.
Apr 8, 2019 at 11:10 AM Post #12,455 of 18,821
Yeah it's been 30+ minutes here with the Poly turned on and the updated Gofigure app. So far no 1.0.41
Apr 8, 2019 at 11:15 AM Post #12,458 of 18,821
On android: Firmware update failed. Please check your internet connection.
On ios: click yes to update, app quits but both lights stay solid blue, no cycling.
Plus ca change...
EDIT: Switched off (waited until P status light off) and restarted. Began cycling the lights without any further input. Odd, but happy!
Apr 8, 2019 at 11:22 AM Post #12,460 of 18,821
It's all good, I just didn't know if it would start to download as soon as it connected to the internet or if it would take a while.
Last time I did this, I bricked it due to unplugging my poly which was on charge and before I knew the last firmware went live. Poly had updated without me knowing, but it is all good now, it was just a temp glitch.
I will leave it sitting.
Can't wait to start taking the combo outside again.
Cheers
Edit.
Updated to 41 no problems, then I had to power cycle as it popped up that I needed poly to be connected to a charger, which it was, but polys light was blue, not white for charging. A power cycle and a gofigure later, it's updating to fun 2.0
Apr 8, 2019 at 11:26 AM Post #12,461 of 18,821
Plus ca change...
Yeah I got that connection error on Android too - power cycling sorted it also.
Apr 8, 2019 at 11:44 AM Post #12,463 of 18,821
For those that have flashed to 1.0.41 and 2.0.
After updating to 41, when pushing the update to 2.0 button, was that update/download more or less instant or did you have to wait ?
I know matt said to wait for 1.0.41 to update, but is 2.0 the same, push update and then wait awhile ?
Apr 8, 2019 at 11:47 AM Post #12,464 of 18,821
Mine updated to 1.0.41 almost instantly, then I had to do the same as you describe above cos it was saying it wasn't plugged into a charger when it was. Now I've set the update going with GoFigure, but it looks like nothing is happening. (I think it did go through a colour cycle when I turned it back on, but it is a solid white light now.) I guess it takes a while.
Apr 8, 2019 at 11:50 AM Post #12,465 of 18,821
Over an hour doing its slow sway disco dance update now - getting nervous - must....be.....patient!
(Has anyone else's 2.0 update completed yet?)
