Got it. Hmmm, still, no sign of the button appearing. Should Poly be in HotSpot mode or connected to WiFi?
https://chordelectronics.co.uk/faqs-category/streamers/
HOW DO I UPDATE POLY TO FIRMWARE VERSION 2.0.0?
Please make sure your smartphone/device is fully up to date before beginning and you have the latest version of Gofigure.
Before starting, and in order to acquire the installation tool (V1.0.41) for the Poly 2.0.0 firmware update, ensure Poly is charged, connected to its power supply and connected to the internet; ensure Poly’s ‘P status’ light is a solid colour and not flashing. Next, follow the steps below:
Updating to 2.0.0 firmware
Step 1
If fitted, remove any Micro SD card. Switch on Poly/Mojo, making sure Poly is charged, connected to its power supply and connected to the internet; ensure Poly’s ‘P status’ light is a solid colour and not flashing.
Step 2
In the background, Poly will download V1.0.41, a new installation tool for the new Poly 2.0.0 firmware.
Step 3
Open the Gofigure App. Go to Settings> General Settings and check the Poly version is now 1.0.41. Next, go back to Settings> Device Settings, you should now have the option to update the firmware. Tap update firmware.
Step 4
Poly’s ‘P status’ light will cycle through a range of colours, showing the update has commenced.
Step 5
Leave Poly until the colour cycle has stopped, this can take up to 30 minutes. Poly’s ‘P status’ light will then show solid colour.
Step 6
Switch Poly off. Re-insert any removed Micro SD card. Switch Poly on. Poly is now ready to use.
