Chord Electronics ☆ Poly ☆ (wireless & microSD module for Mojo) ☆★►USEFUL INFO on 1st PAGE!!◄★☆
Discussion in 'Portable Source Gear' started by Matt Bartlett, Jan 5, 2017.
822 823 824 825 826 827 828 829 830 831
833 834 835 836 837 838 839 840 841 842
  1. Matt Bartlett
    Yes it is!
    Chord Electronics Stay updated on Chord Electronics at their sponsor page on Head-Fi.
    https://www.facebook.com/chordelectronics https://twitter.com/chordaudio http://www.chordelectronics.co.uk/
    STR-1, 514077 and miketlse like this.
  2. Feedbacker
    Aha - I have cycling colours!
  3. Azirius
    I’m happy to report mine has successfully updated. Nothing major to report here, seems much the same as before, but we shall see what it’s like over the course of the next week or so. I don’t subscribe to either Tidal not Quobuz so those options don’t benefit me, unfortunately.
    The update went smoothly, just not enough information present to confirm what was going on, which is expected when your UI consists of two LEDs.
    Nice work guys in any event. I’m hoping this release fixes everyone’s Poly and they can enjoy their devices.
    lawshredpower likes this.
  4. Amberlamps
    It's done, 2.0 alive and kicking.
    However, can I get it as a download file so that I can flash it over usb next time, as your update process scares me.
    Ta!
  5. kornhead
    Mine has updated to 1.0.41 but the Update Firmware button hasn't appeared in GoFigure App.
  6. Gr8h8m
    Have you updated GoFigure?
  7. Matt Bartlett
    To anyone with slow updating just to clarify a couple of things.
    1. Your Poly must be connected to a charger and on charge.
    2. The micro SD card should be removed before you switch on otherwise the update cannot install.
    zenlisten likes this.
  8. Gr8h8m
    They've resisted allowing downloadable updates for some reason. I agree, I don't like the obfuscation either!
  9. Matt Bartlett
    Just double check you have the latest Gofigure app installed. The firmware button does not appear on the older version of the app. Also have you power cycled after installing V1.0.41?
  10. Matt Bartlett
    No I'm afraid not. The micro USB is for charging only and updating via the micro USB is not possible.
  11. Gr8h8m
    Copy that - was careful about both.
    90 minutes later and still going red...green....blue...
  12. lawshredpower
    Took me almost an hour to get the .41, but the 2.0 update completed in less than 5 minutes!
    Also, I had to do that as well!
  13. Gr8h8m
    @Matt Bartlett - how long should I leave it updating (currently 100 minutes)? If necessary is there a way of rolling back and updating again - factory reset and update - or something else?
  14. kornhead
    Yes, I think so.
  15. Matt Bartlett
    I'm just talking with the software guys and will get back to you asap. I'll PM you back as soon as I can.
    Gr8h8m likes this.
