I've really have been enjoying Roon on the Poly for the last few weeks. I now understand from my initial questions that Roon must be on the same LAN and can't be used while out and about.
@jarnopp, I'm not following your explanation (quoted here) and perhaps it is associated with my new observation/question- it appears that I can only use Roon on the same LAN and in normal WiFi (not hotspot) mode. So if I come in from using Poly in hotspot mode, I have to launch Gofigure, switch from hotspot to normal WiFi mode, and then select Roon on the Poly. Is that the correct sequence? I initially thought that while in hotspot mode, I can toggle Roon on from Other, but Roon does not appear to load even though Gofigure allows me to toggle to Roon. So, the question is- how do I use the Poly to access Roon while in hotspot mode and on my LAN?
