Gr8h8m
- Jul 11, 2005
Note 8 stopped connecting to Poly again about a week ago. Doubt I'll bother with GoFigure again until next update - too frustrating!Same here, iPad gofigure sees it fine though.
[QUOTE="masterpfa, post: 14474320, member:To start with you could use Mojo and connect to your phone via OTG if the features required are primarily SD card usage and if Tidal/Qubuz etc are also needed these will play via apps like UAPP or BubbleUPNP.
With the GoFigure app, set up is relatively straightforward. Once set up, choices will be down to what app you use to playback material. I personally use M.A.L.P for Android for my SD card playback and BubbleUPNP for streaming
The issues experienced initially, especially for Android users were, for some, not having an app like GoFigure to configure the device, this is now available as a Beta and has eased the setting for some (OK: for me at least). The only problems I have are usually down to my phone and connection ie Hotspot not turned on and not the Poly.
I picked up an AQ drangonfly red for on the go. It's not as good of sound with SE846s if I have a super quiet room, but for trains and office it is more portable and sounds nice.Note 8 stopped connecting to Poly again about a week ago. Doubt I'll bother with GoFigure again until next update - too frustrating!
If it's brand new I think the solution would be to exchange it for one that is A-OK out of the box.I just received my new Poly. The first night did not end well. The microsd-card got stuck in the tray after the first insertion. When I removed the four screws, tilt the chassis lightly while pushing the card it ejected. Since I'm at work now I don't have much tinkering time but would releasing the screws just a bit be a solution?
If it's not right brand new out of the box they should swap it for one that is, not repair.You're right Graham, I'll send it back for repair.
No you didn't. The update will happen silently, without any indication by lights or other, when it connects to the net. It also won't confirm when its done - you'll just have to reboot and check its firmware number. I think it's a poor process personally - a couple of people have temporarily bricked their units because of an incomplete/borked update.It's in the mail already. I read your post while I was mailing it jarnopp, and Graham is right, it's new, it should work perfectly. I'm going to get a credit and I can buy another one. Yesterday besides those issues it wasn't possible to kick Poly into firmware update. It was in version 1.05 so I couldn't use the dedicated Chord app for updating. Somewhere in the manual I've read that all lights will blink each at a time while updating and that it should start automatically when connected on the network. In a different version of the manual it says there is a link in the WiFi connection of Poly itself for updating to the newest firmware (nowhere to be found in the WiFi settings page of Poly). Because the software evolved the manual clearly didn't. It was frustrating to get everything connected but not seeing the 'automatic firmware update'. Did I do something wrong?
There has been no indication of a Poly 2. Recently Chord have been working flat out on preparing the production/launch of MScaler, TT2, Etude, plus finalising the Poly Android app, so I doubt that they have had any time to consider a Poly 2.Oh dear me, it is for stuff like this I'm a bit hesitant about giving Chord £499 for Poly, and the retail price has only come down by just a few £s. I wonder if there a Poly version 2.0 coming out?
Don't be too scared by @Syracuse problems with updates. Part of the issue is that his Poly was running version 1.05 software, and he misunderstood the procedure to update to the current version 1.26 of the firmware. This has confused some posters, but there is a wiki, plus a large community of owners here, such as @Gr8h8m who are happy to help explain things for newbies. There is also Chord Support always willing to help.
Regarding the tight card slot, it is frustrating for him, but I can find only one other instance of a Poly with the same issue on this thread - so it isn't an issue affecting every Poly.
Cool! It's got its quirks and idiosyncrasies but ultimately the sound makes it all worthwhile imho and the user experience should only get better over time.Thank you for the reply. Yes @Gr8h8m has been very helpful. I've returned the Shangling M0, it's too small for ones normal sized fingers. I will pull the trigger, but of course I have to convince the wife that it's a necessity . When it arrives I will post again for assistance, thank you once again.
