Chord Electronics ☆ Poly ☆ (wireless & microSD module for Mojo) ☆★►USEFUL INFO on 1st PAGE!!◄★☆
Sep 4, 2018 at 3:42 AM Post #10,817 of 19,927
How should one use M.A.L.P.? Can you guide me through? I don't even see where I can connect to Poly.
1) Note down Poly's IP address. 2) Create new profile in M.A.L.P with this address (don't need to change anything else) and save. 3. It will connect using this profile and populate a library of material from the SD card.
Note, there's currently a bug in Poly's firmware so DSD/MP3 files won't show in library view. Just browse for them using files view. Note also that this all becomes much easier if you can assign Poly a static IP address.
Sep 4, 2018 at 11:51 AM Post #10,820 of 19,927
Well, from the past couple of days my GoFigure app on Android isn't finding any Polys. Does anyone have this issue?
Thanks
What is the colour of the setup light on the rear of the poly? Bluetooth is open on the smartphone and recognize the poly? You tried too in hotspot mode? Poly mojo is fully charged?
Sep 4, 2018 at 11:57 AM Post #10,821 of 19,927
To answer, my friend's iPhone GoFigure app finds it :-) so I don't think there's anything wrong with Poly side of things. Let me uninstall and install the app again. I shall come back to you.
Thanks...
Sep 4, 2018 at 12:20 PM Post #10,822 of 19,927
Thank you for your answer! Where can I monitor Poly's IP adress?
Sep 4, 2018 at 12:22 PM Post #10,823 of 19,927
Download Fing
Sep 4, 2018 at 12:28 PM Post #10,825 of 19,927
Sep 4, 2018 at 1:03 PM Post #10,828 of 19,927
In the form you have the link to download the Android gofigure no?
Sep 4, 2018 at 1:08 PM Post #10,829 of 19,927
Thanks
Fwiw my note 8 has stopped connecting for me as well with Poly via GoFigure (though sees it as a Bluetooth device) the last few days I've tried, despite repeated rebooting / stopping and starting app / going round the houses.
