kornhead
- Dec 25, 2015
Yes, thank you!In the form you have the link to download the Android gofigure no?
That's exactly my case!Fwiw my note 8 has stopped connecting for me as well with Poly via GoFigure (though sees it as a Bluetooth device) the last few days I've tried, despite repeated rebooting / stopping and starting app / going round the houses.
Fing shows zero devices. Should I connect to Poly in network mode, right?Download Fing
My Fing version shows refresh button to the left of the gear in the upper right corner. And yes, I have refreshed it.You have refreshed the page?
Have your phone had an android update, or a security patch update recently? I remember android updates used to reset some of Note 3 settings, and introduce lots of clicks, when I used it as a source for Mojo. There was a security update patch a few days ago, so maybe that has reset some of your settings, and stopped you connecting to poly.That's exactly my case!
I did receive one but I am quite sure that I used GoFigure after the update. Either way I am able to connect through the normal Bluetooth under connections. It's only the GoFigure that stopped connecting to it.Have your phone had an android update, or a security patch update recently? I remember android updates used to reset some of Note 3 settings, and introduce lots of clicks, when I used it as a source for Mojo. There was a security update patch a few days ago, so maybe that has reset some of your settings, and stopped you connecting to poly.
Just uninstalled / reinstalled & its connecting again.Have you tried to reinstall go figure?
Strangely I still can't connect to it with re-installationJust uninstalled / reinstalled & its connecting again.
OK, I figured it out. But how to assign Poly a static IP?1) Note down Poly's IP address. 2) Create new profile in M.A.L.P with this address (don't need to change anything else) and save. 3. It will connect using this profile and populate a library of material from the SD card.
Note, there's currently a bug in Poly's firmware so DSD/MP3 files won't show in library view. Just browse for them using files view. Note also that this all becomes much easier if you can assign Poly a static IP address.
The exact way will be determined by your network devices. At home my router does it. While out and about my phone does it as it makes its own network that Poly joins. Then I have 2 profiles in MALP - home and mobile.OK, I figured it out. But how to assign Poly a static IP?
Poly joins your mobile phone anyway on the go. But i guess it doesn't provide a static IP, right?The exact way will be determined by your network devices. At home my router does it. While out and about my phone does it as it makes its own network that Poly joins. Then I have 2 profiles in MALP - home and mobile.
Actually it does (although its different than home one) Phone is Note 8, can't speak for other Androids.Poly joins your mobile phone anyway on the go. But i guess it doesn't provide a static IP, right?
OK, I`ve figured it! In my case it also does.Actually it does (although its different than home one) Phone is Note 8, can't speak for other Androids.
