Chord Electronics ☆ Poly ☆ (wireless & microSD module for Mojo) ☆★►USEFUL INFO on 1st PAGE!!◄★☆
May 28, 2018 at 8:45 PM Post #9,767 of 19,970
Nirvana is red. For sure.
fF9Bky
May 28, 2018 at 8:50 PM Post #9,768 of 19,970
May 28, 2018 at 8:56 PM Post #9,769 of 19,970
Has anyone found a consistently reliable way of bypassing AirPlay on iOS devices? I managed it once, and got glorious hi-res and DSD from the Poly's SD card, but never again.
FWIW, I generally use hotspot mode and Glider, but I'm happy to try any other config that is shown to work.
May 28, 2018 at 9:00 PM Post #9,770 of 19,970
fF9Bky
Lovely. I have the K10s also and they match beautifully with the mojopoly but definitely get upgrade cables as they really enhance the sound.
May 28, 2018 at 10:17 PM Post #9,771 of 19,970
https://github.com/CDrummond/cantata/releases
Just tested and it will play DSD 256 and also does gapless playback.
i dont know what to type in the LOCAL HOST. i would like to play my music files (DSD files) from my windows library to Poly. my music player is JRiver Media Center 24. all files except DSD 256 ones can be played thru Poly. thanks!!!
May 29, 2018 at 7:36 AM Post #9,772 of 19,970
Enter Polys ip address, say for example, 192.168.1.x. X= Number from 1-255
Or you can enter the name of your Poly.
Example, mine is named Chord Poly.
Try and find polys ip, it should be similar to the above or depending on what router you are using, it could also start with a 10 or 172.
But 192.168.1.x is likley to be the one you use.
May 29, 2018 at 9:34 AM Post #9,773 of 19,970
This is setting up an MPD client on your PC to play back files from the MPD server on the Poly (that reside on Poly's SD card). From your description that doesn't sound like what you want to do?
May 29, 2018 at 9:39 AM Post #9,774 of 19,970
yes.. exactly.. my problem is, DSD 256 files could not be played via Poly.. all other files can be played via Poly using JRiver Media Center as my source.
May 29, 2018 at 9:43 AM Post #9,775 of 19,970
Im not familiar with PC apps that will stream DSD256 - but you can play them so long as they reside directly on Poly's local SD card using eg Cantata for PC (which is what you were setting up) or MALP for Android. I just wanted to make sure you weren't misunderstanding!
May 29, 2018 at 9:52 AM Post #9,776 of 19,970
all my music files are stored in an external hard drive which i use as my music library. im using the JRiver Media Center as my audio player. all music files, i can play them via streaming thru Poly, ecxept DSD 256 files.
May 29, 2018 at 9:55 AM Post #9,777 of 19,970
no worries.. im seeking advice from you guys because im new to this.
May 29, 2018 at 9:56 AM Post #9,778 of 19,970
You will find it a problem to stream DSD natively to Poly. DLNA/uPnP (currently) doesn't support it. Airplay won't ever support it.
