priest331
Is it doing that without transcoding? What colour does Mojo light up while playing?
that bright white light.
Wow! So cool! Glad to always learn something new! What protocol is it using to stream to Poly?that bright white light.
Have you contacted Chord directly? If so, what did they say?JRiver can play almost any audio file via Poly. except DSD 256 files. the MOJO lights change with the file type that is being played. with DSD 256, the lights change but there is no sound output
I can stream DSD over DoP (white light) from Logitech Media Server and MinimServer using Orange Squeeze/BubbleUPnP on Android or iPeng/mConnect on iOS.You will find it a problem to stream DSD natively to Poly. DLNA/uPnP (currently) doesn't support it. Airplay won't ever support it.
That's using MPD though isn't it? (Glider uses DLNA to index then MPD for playback)
and MALP is 100% MPDM.A.L.P.
