keithmarsh
Hi Keith,
Where are you located? I can put you in contact with a local dealer that stocks the cases.
Thanks
Thank you. I'm based in London too!
Hi Keith,
Thanks
I’m interested too- based in London.
I was debating getting the Poly and checked a few US vendors and noticed the Chord Poly at moon audio was $749, did they decide to jack up the price for some reason?
Me too please Steph, London/Kent basedHi Keith,
Thanks
Here's a GoFigure product shot from a German magazine earlier last year October.
For those reading German and interested in the article, you can read it here.
Now that was a pretty glowing review- I am loving the look of GoFigure and how restarting Poly seems to no longer be necessary.
I have been growing more and more attached to Poly ever since I had it replaced. Having to constantly delete and reinstall Glider is a bit annoying but a small price to pay for this level of music enjoyment!!!
I am definitely starting to become a believer in Poly.
Had my exchange unit but all is not well, unless I'm doing something very wrong.
I can't get the p status light to come on at all now!
I charged the Poly alone 10hrs ... conneted to Mojo and switched on, no p status light after 10min wait.
Then I charged Poly and Mojo connected together, 10hrs ...... Switched on, no p status light after 10mins wait
Put charge cable in, switched on while charging, the same no p status light.
Ok, tried using config pin, held in but of course it would not go into access point, just thought I'd try it.
Disconnected poly from mojo reconnected, still no p status light.
Formatted SD card just in case, no change.
Worried about "hot" disconnect/reconnect so not tried that.
It's been sitting here now for an hour, no p status light.
Help please guys
Does anyone know a UK retailer that stocks the Van Nuys ‘Mojo Poly Premium Leather Case’?
The only online stockists I’ve found appear to be in the Netherlands and Norway...
Last few of times that I added tracks to my SD card, I've deleted all db/cache files from the card so Poly would re-build them. Of course, Poly goes into it's disco-strobe mode while it is building the files. Each time, I waited several minutes after the p.light went solid before turning the Poly off. Each time, Poly goes through building the files a second time when I turned the Poly back on. I'm confused: why would Poly build the files a second time? Do others experience the same thing? Is this expected behavior?
A couple of things to check:-
1. Make sure you are on the latest firmware 1.0.17
2. You have some free space on your SD card. If it is full the database cannot write to the card so every time you switch Poly off and back on again it will retry to write the database and you will get the disco lights.
