Chord Electronics ☆ Poly ☆ (wireless & microSD module for Mojo) ☆★►USEFUL INFO on 1st PAGE!!◄★☆
Feb 8, 2018 at 9:48 AM Post #6,662 of 18,784
Hi, My concern is that even if your Poly currently works with your Mojo, it may not work with a future owner's Mojo.
A lot of people like to recycle their old kit when buying new stuff, and I can imagine a lot of people being upset when they buy an apparently faulty used Poly.
Perhaps knowing the serial numbers of affected Mojos and Polys might help.
Chord has said that there is an issue with a limited number of Mojos with a faulty component. To me if you are taking ownership as a manufacturer you recall the defective products and make the S/Ns available. Not sure why there is even any question about that. Mistakes happen and you just need to own them. But not owning it is a worry. There could be a number of reasons from lazy, not enough resources, not customer centric, through to financial risk in the most extreme circumstances. In this case I am not going to speculate or make any assumptions. Just want Chord as a respected company to do the right thing. Make sense?
For me I do have nuisance power-up issues (especially when cold). Been pretty consistent on my posts... generally happy other than power up is never the first time (hence the reason I want to rule in or rule out if I have one of the impacted units with release of S/N#s), like all looking forward to seeing the very long awaited (overdue) app, and most recently determining that the Van Nuys Premium Leather case might not be made available in North America (more to come on that) .
Hopefully that puts the post reply from a prior in prospective. Like this post if you agree or feel free to make a negative comment.
BTW - Still a Chord/Rob fan and looking at the Hugo 2
Feb 8, 2018 at 9:52 AM Post #6,663 of 18,784
I can confirm that I have this as well.... in Glider latest beta 1.8.0 build 1.8.0.16 running iOS 11.3 second beta.
Only when the playback is paused and the Mojo shows purple (DSD256) the high pitch sound is emitted... when playback resumes the pitch noise goes away.
So when the DSD clock is received through playback the signal from Poly to Mojo is locked at 11.2MHz (the DSD256 sample rate). I assume when paused the Mojo/Poly looses the reference clock but the Mojo continues to indicate the purple colour proving that the sample rate stays "locked" where is was set during playback.
This occurs when streaming from the Poly's mSD as well as my Synology NAS.
@Matt Bartlett can you replicate this? It occurs with DSD256 but not with DSD128
Edit: Will try to play these files locally from the iPhone using Glider 1.8 beta which supports iTunes file sharing and connect the iPhone with Apple's CCK cable directly to the Mojo. This way taking the Poly out of the equation it will be easier to isolate the problem.
Thanks for taking the time to try to replicate the issue in your unit.
:beerchug:
Feb 8, 2018 at 10:14 AM Post #6,664 of 18,784
Hopefully that puts the top post of this page in prospective. Like this post if you agree or feel free to make a negative comment.
I was in the same boat and emailed Chord and they are swapping out my Poly. At this point, I don’t think your Mojo SN matters, because whether a component was “faulty” or just a bit out of spec for what Poly expects, it seems they have redesigned the Poly itself to be triggered on by a different method, not Mojo voltage but some other state change. So, if you have an issue at all, you’d want a new Poly version. Mojo SN is irrelevant now. If there is even a consistent pattern to which Mojos generally work well or not with the initial Polys.
Feb 8, 2018 at 10:23 AM Post #6,666 of 18,784
I was told almost two weeks ago it is "imminent".
We need a GoGuessWhenGoFigureAppIsReleased app.
Originally we were told it was imminent back in late October of 2017.
Feb 8, 2018 at 10:24 AM Post #6,667 of 18,784
Since the last firmware update, mine powers within a few seconds. As such, I would say you should email/call the guys at Chord to get yours exchanged.
Feb 8, 2018 at 11:05 AM Post #6,669 of 18,784
same boat as...?
Feb 8, 2018 at 11:39 AM Post #6,670 of 18,784
Feb 8, 2018 at 12:55 PM Post #6,672 of 18,784
Yes, as StevieDVD said. The slow power on issue (4-5 minutes, usually 2-3 power cycles when cold). Perhaps the "recall" of many of the initial units is behind the price increase. Maybe they can be retrofitted and sold as refurb for less!
Well kudos to Chord today. Emailed them with my issue and device info. Tom @ChordElectronics got back to me within hours and indicated the description sounds like a replacement Poly is in order and will be allocated. They will work with my dealer @MoonAudio (not Moon Electronics... Inside joke)
Feb 8, 2018 at 3:31 PM Post #6,674 of 18,784
I am wondering if it's worth buying a Poly to use only as a file source from SD-card. Meaning no worries about getting it to connect to wifi etc. ....... Is the only issue then to worry about, the switching on thing? Or if the Poly will talk to the Mojo?
I'd like to get a portable music solution. I could of course use a phone, but that makes a large item to put in a pocket. My last option is that I have my mind on the Sony NW-ZX300. It has great battery life and a growing number of legion of fans. (Many saying it's close to the flagship Sony DAP.) I am still waiting for pro-reviews myself. The ZX300 is supposed to be very good sounding. I would be happy that it most like will not match the Mojo/Poly. However I really don't mind that.
Feb 8, 2018 at 3:43 PM Post #6,675 of 18,784
I think those who had the issues are all being taken care of by Chord. My wife's sole use now is SD card. I think those who received replacements seem to all be happy. I think it is safe to make the investment.
I hope to buy Hugo 2's "2go". the Poly of Hugo 2 for the same reason: I can bring 400gb of music with me anywhere,. and listen with superior sound quality. What's better than that?
2Go likely delayed as the focus seems to be on Poly, but my confidence remains the same in Chord quality and customer service.
