Muzslya
The GoFigure app's icon will look like this.
Majority? I’m on my second Poly and I have never had to resort to anything like that to wake it up.
The majority of "problem" posts I've been following here concerns the power on issue just as my Poly is experiencing. That's what I mean.
Well, by coincidence, I charged my MojoPoly, as a unit, yesterday and both were displaying blue lights indicating both were fully charged. When I came to switch it on this morning, my Poly wouldn't start at all. So I attached it to power and, sure enough, Poly fired up. What was odd though was that when I disconnected the power cable, Poly was blinking red light whilst Mojo was blue, so Poly had fully discharged itself in less than 24 hours.
Has anyone else experienced this? I have not had this happen before. It may not be related, but now Poly is taking several attempts to power up with Mojo. I have always had a slight concern about the Poly battery life since I learnt of the Poly being in an always on state.
Well, that could mean you're in the minority then. But then again, you are on your "second" Poly.
I thought the fully charged was both white light - are you sure your charger is up to charging both together? if Poly charged OK on it's own and lasted OK, but not when both Mojo & Poly are done together, then I'd suspect the charger first.
I have experienced exactly the same thing over the last week since the update. I have not had a single issue with using Poly before this.
@Malcyg
I had only one time this event. It was saturday after the new firmware. This week, i check each day and the Poly led was blue.
Before the new fw when Poly was cold i heat it in my hand and then it starts quickly.
Now if Poly is cold I connect it to a power bank and Poly start in 10 second.
Hi. Let me check on this for you. I think we will be bringing that case in but need to check for you first.
We should have some coming over soon. I will make a post when I believe they will be available from your retailers to order.
