after reading the manual can i turn my ipad mini on to connect poly to my network then turn the ipad off. i will be using my mac for roon which is hardwired?
Yes, you can.
Maybe so just be aware of thr poly/mojo case, the wristband can break off mid use, i lost my mojo/Poly/case in a lake because of it ... Now I'm out of luck
That's really bad. The wrist strap must be to easy to disconnect. The first time I used my case was for a trip. I place Mojo/Poly/Case in my pocket. I exited the airplane and walked through the terminal to another gate and boarded an airplane. Sat down and reached for Poly/Mojo/Case and the strap was MIA. I have no idea how it was lost. After reading @NaiveSound 's experience, maybe I am lucky to have lost the strap without loosing my Mojo/Poly.
I recommend Poly Case v2.0 comes with a built-in flotation device. And a GoFloat app. I hope John & Matt see this.
Sorry for your loss.
You are very very lucky i am devestated, I was in the process of creating a YouTube review and instructional on use with pc/mac/android/iPhone
I loved it so much .... Truly a big loss. I don't have $ for another bundle...
I wish it was a better built case? Or maybe it was a secluded isolated incident?
But like you..... It's shocking.
Just wish I could get help in these ssituations
I’m really not too happy about that the above statement. You seem to have a rather short memory Eduard, you may recall we at Chord helped you considerably the last time you had problems with your Mojo. I’m very disappointed that our considerable help and generosity didn’t leave a lasting impression and now. you feel you have to imply we owe you more. You know full well this is not the first time you’ve tried to wangle freebies from us. I’m Also a little surprised that we haven’t already heard a great deal from you on this thread concerning actually using a Poly.WowW.. You got it dobe right I'm happy it was resolved.
I unfortunately am stuck with a wristband no body wants to help either as far as manufacturers go
Did anyone wrist wrap break off the poly case mid use? I lost poly/moko/case because of it
roon plays tidal flac 44.1/16 files. when roon streams from my mac to poly is it an exact copy of the 44.1/16 flac tidal file and if so how is this possible by radio wave transmission. or is the poly roon streamed file inferior ie i'm not listening to full tidal lossless flac?
connecting to roon seems very easy thanks jarnopp.
