Delighted to report that Poly has worked over office wifi with glider two days running, and using its own hotspot last night at a hotel (I couldn't be bothered to go through the hassle of adding the hotel wifi just for one night). So I am seeing the light at the end of the tunnel.
Chord Electronics ☆ Poly ☆ (wireless & microSD module for Mojo) ☆★►USEFUL INFO on 1st PAGE!!◄★☆
- Thread starter Matt Bartlett
- Tags
- chord chord electronics mojo poly
Mightygrey
Does that mean I have to put the Poly into hotspot mode in order to use mpd (meaning I can't use my phone to connect to the net/4g)?Hey @Mightygrey - M.A.L.P on Android is playing gaplessly no problem. It's the only working solution I've found so far.
God damn this is frustrating.
Gr8h8m
- Jul 11, 2005
No - I make the phone itself make a hotspot when out and about, or just connect to home network when at home. You have to tell M.A.L.P the IP address of Poly, so I assign it a fixed IP at home and the phone hotspot seems to always assign it the same one, and then have 2 profiles in M.A.L.P. Sounds more of a faff than it actually is, but I wouldn't exactly describe it as being for the mass market! (Whoever thought of putting ads in Underground stations is having a right larf I reckon).Does that mean I have to put the Poly into hotspot mode in order to use mpd (meaning I can't use my phone to connect to the net/4g)?
Mightygrey
Ahh I see. If it's not too much trouble, on the "edit profile" screen, what exactly would I enter in each field for, say, my home wifi or mobile hotspot network inNo - I make the phone itself make a hotspot when out and about, or just connect to home network when at home. You have to tell M.A.L.P the IP address of Poly, so I assign it a fixed IP at home and the phone hotspot seems to always assign it the same one, and then have 2 profiles in M.A.L.P. Sounds more of a faff than it actually is, but I wouldn't exactly describe it as being for the mass market! (Whoever thought of putting ads in Underground stations is having a right larf I reckon).
- host name or IP - my poly's name?
- port - 6600?
- password - my wifi password?
Gr8h8m
- Jul 11, 2005
Put your Poly's IP address in and that's it - no password required!Ahh I see. If it's not too much trouble, on the "edit profile" screen, what exactly would I enter in each field for, say, my home wifi or mobile hotspot network in
- port - 6600?
Mightygrey
Would that be Matty_G_Poly:local (my poly's name being Matty_G_Poly)? Thanks mate!Put your Poly's IP address in and that's it - no password required!
Gr8h8m
- Jul 11, 2005
Being on Android I never got that myname.local trick to work. You put in 192.168.xx.xx etc whatever address the router has assigned the Poly when it logged on.Would that be Matty_G_Poly:local (my poly's name being Matty_G_Poly)? Thanks mate!
Mightygrey
Sorry to be a pain again, but how do I find that out? Jesus, how did they expect to advertise this and expect the average music-enjoying commuter to ever make it work...
Mightygrey
Never mind the robot lady told me. Success! I've finally been able to get gapless playback FOR THE FIRST TIME SINCE OCTOBER. What an absolute shambles.Being on Android I never got that myname.local trick to work. You put in 192.168.xx.xx etc whatever address the router has assigned the Poly when it logged on.
Gr8h8m
- Jul 11, 2005
I'd suggest making that a fixed IP if you can to avoid having to refer back to the robot lady when/if it disappears from M.A.L.P cos it's been assigned something different on next boot.
Yeah it's not exactly plain sailing is it!
- Jun 4, 2007
Still having issues, still only stays connected to glider for 30 seconds (same for media centre too), this is using my own WiFi, I have forced it to its own 2g only WiFi network.
Even using Poly's own hotspot its the same, well kind of, i Start playing, then immediately goes to music offline, and glider starts searching and finds nothing, meanwhile Poly is still playing.
Strangely enough glider still tracks the track its on, and poly carries on playing, glider also says this device is not capable of playing this song, and lest me ship tracks lol
Poly 1.0.10
Glider 1.70.14
Poly 1.0.10
Glider 1.70.14
NaiveSound
- Nov 8, 2015
Did anyone wrist wrap break off the poly case mid use? I lost poly/moko/case because of it
Signal2Noise
Is there a Poly app for you guys yet?
Lol. No.
The app is apparently called "GoFigure". May as well call it MissingInAction.
corius
- Oct 9, 2015
Lol. No.
I'm not convinced that that will be the name for the App. A much more likely conversation would have been...
"Matt, what are we calling the Poly App, and when will it be ready?"
"Go Figure, John"
"Great idea Matt, I'll give that to marketing straight away"
would it be too risky to buy a poly now if i were to use it just for streaming roon from my imac?
Total: 114 (members: 5, guests: 109)
