BluebirdCRM
Member of the Trade: Bluebird Music
Hi @Matt Bartlett - that's not strictly true right now is it? Bubble DLNA playback of local SD card files is broken (or at least it is for me - this is on Android). The stream will consistently bork and stop after 10 minutes or so, with the Poly falling off the network. MPD playback through M.A.L.P is pretty reliable though, with just a few glitches here and there.
Hello Gr8h8m. Does Poly ever drop off the network when using M.A.L.P? I have had good luck in the past with BubbleUPnP and the SD Card. But I am going to let my Poly run on Bubble for a while and see if it is stable. Also you might try rebooting your router to see if UPnP/DLNA use with Poly is more stable.
