supervisor
i guess i have to buy a new Mojo. who wants my old one?
Of course this is not a conclusive test, just a mere indication of the differences I have experienced so far. I have tested back and forth a lot since I got the new Mojo yesterday and there is no doubt the newest Mojo triggers the Poly much faster both in normal room temperature and when colder, every time. Since I got the Poly I have of course used it a lot with my old Mojo and the power on time has varied from short to not powering on at all, but it has been nowhere as short as I have seen the last day with the new Mojo. Also the Mojo power button cycling through the colors and then latch on red or purple hasn´t happened once yet with the new Mojo.
I have no wish to draw any conclusions after such a short time. But I do find my observations very interesting.
Chord has never acknowledged the power-on problem or a planned fix.
no, that is incorrect. we got a firmware update right before christmas and this was already a known issue at that point. they've just never responded directly to this specific issue. and safe to assume they've likely been on vacation all week.
...in the UK a lot of companies don't return to work until the 2nd of January or is it something more sinister.
To be fair this test needs a few more variations to be a reliable indication of a Mojo part in the power-up delay of the Poly.
1. If new Mojo & Poly left off for say 20 minutes does it power up Poly just as fast?
2. If after the above test you switch off and swap back to the old Mjo does it still have a delay in powering on the Poly?
3. Are both Mojos fully charged.
I'm not saying that the result you show is wrong just that more factors can be involved. I've worked with software for several decades now from testing to designing, though nothing involving control of electronics. I learned in the early days that the subtle differences in a user reporting the sequences to recreate an issue could vary, especially the intermittent issues. The phrase 'it works on the second try' etc always makes me smile. Coders here will hopefully know that variables should be initialised or preset, if not the first use can have odd results but once set it works as expected.
All I'm saying here is that we don't know if the Poly started with the new Mojo quicker as a result of an interaction a few seconds earlier when attached to the old Mojo. The likelyhood of the outcome of your test being correct is probably on the money but if Chord repeat this they would need to use several Poly/Mojo combinations all starting the first boot sequence.
Personally, I don't expect the power up to be a firmware issue. I hope that Chord can identify the build variations of Mojo & Poly units by the serial numbers and would suggest anyone with power issues raise a support issue directly with Chord. Would also suggest that the units are fully charged with a 2A plus charger as that's likely to be the first thing they suggest you try.
I don't think its reasonable to expect them to be on here and replying 24/7 especially during the Christmas period. It is reasonable to expect them to shine a light on and fix the start up issue in due course though.
Matt and all Chord staff are on vacation until Tuesday the 2nd of January. the same goes for our design consultants responsible for the Poly. I ceased posting due to the vile personal abuse from some particularly “interesting”people on this thread.
So please understand work is ongoing and information is just from my own understanding at this time!
We are of course, aware of the power up issue. However it’s not simple because Poly can take time in powering up because it’s looking at the WiFi landscape, if it’s complex, it take longer this confused people especially at first, But underlying this some (a few ) Mojos we have discovered are giving a lower voltage (fortunately only) at lower temperatures out of their usb’s than the rest. This is due to a particular batch component, a type of input protection rectifier in the batteries charging circuit of a few Mojos. Please note that we have already altered the design of the switch on circuit within Poly to now look for a change of state and not a particular voltage to determine if Poly must turned on or not.
Despite what has been said erroneously on this thread we take at Chord take pride in supporting our customers. So we will naturally be replacing the Polys for those customers who’s units are exhibiting the problem to the build standard of Poly that can accommodate the odd performing Mojos,
I have also been advised concerning the outstanding connection issues Poly has associated with multi hub mostly large professional style American WiFi set ups will be resolved in very short order now ( many thanks to those like Jeremy L that helped with the great accurate feedback) along with other issues update prior to the release of the Gofigure app. All of which I must now apologise that we didn’t quite make the Christmas or New Year date for a finalised product that had been on all yours and our own wish lists,?
Are you able to publish the S/N numbers of the batch of Mojos with this input protection rectifier issue?Matt and all Chord staff are on vacation until Tuesday the 2nd of January. the same goes for our design consultants responsible for the Poly. I ceased posting due to the vile personal abuse from some particularly “interesting”people on this thread.
