jarnopp
- Nov 26, 2014
I think what might be really helpful is for those who have a reliable and working Poly over home or office Wifi and who are using it to stream DNLA or Roon to tell us your specific configuration. Brand of router, brand and number of WAPs, how you configured the SSID and Wifi channel, your Poly configuration, etc. There is either something different about the networks that are working and those that aren't or there is a batch of bad Poly's out there that need to be exchanged for ones that work. Without more detail on those that are working it will be impossible for anyone to figure out the answer.
I’m convinced that my network was the problem. Whether Poly may be more (too?) sensitive to configuration, that may be. But Roon, DLNA, and hotspot away from home all work very well for me. Just hate that pin! If warmed or recently charging, it will turn on pretty reliably. If not, I usually have to break the Mojo/Poly connection and reassemble while on to get Poly to turn on. This mostly since 1.06.
I also used to get dropouts at my listening location over AirPlay with an Apple TV. Same when I first got Poly. I upgraded the supplied modem/router with a Netgear from Costco. No other APs. I tried various channels after scanning the environment. Initially had good luck with channel 1, but then other networks started to conflict. I set the router back to letting it decide. Really, no other special settings. All lowercase SSID with no spaces or special characters.
I actually could not be happier with the sound from MojoPoly over Roon and other modes. When the convenience factors are addressed with the app, even better. I know it’s not everyone’s experience, and I can’t even say it’s network issues for everyone where it’s not working, but just reporting my experience. Hope it helps.
