Another “data point” reporting for duty.
TL;DR — IMO, this is not ready for prime-time. However, there is a wonderful gem in there that will require a lot more polishing. In the end, I’m (personally) confident this will shine very brightly. In the erstwhile, if you need perfection from this, please wait a while longer before diving in.
I received my Poly last week from TTVJ. There was a print out inside the shipping box from Bluebird Music titled, “Poly Need to Know Set-Up Tips.” I was intrigued by 3 of the 16 points listed.
- Please read the manual carefully.
- Please re-read the manual.
16. In addition to solid network infrastructure, Customers need a fair bit of network experience to use this product, it requires patience and is not plug and play.
In short, RTFM (but maybe not as carefully as the first time
) and you will probably run into problems.
I believe that the hardware is up to challenge that Chord as undertaken. But hardware is not much good without proper firmware and software. Another poster speculated that a couple of more firmware updates will fix most everything. I’m not sure it will only be 2 updates, but it will happen in the very near future, imo.
I’ve tried Glider, 8 Player, and Creation5. Of these, I’ve been working mostly with Glider.
@joe28 has been wonderful to work with. I can’t speak highly enough about his thoroughness and responsiveness. I’m using latest build (30) of the beta, and it is getting real close.
Yes, there are a LOT of problems I’ve run into, similar to other posts. One issue that hasn’t been raised (I think) is losing complete connection when moving between WiFi nodes. I have an AirPort Extreme and 2 AirPort Expresses hard-wired together. Most all of my equipment is hard-wired; very little operates over WiFi. I’ve had this issue using all three apps. Even happens using Audrivana+.
Am I frustrated? Yes. Is it getting better since I got it 5 days ago? Absolutely. I’m willing to be patient and work my way through these issues.
regards,
rob
