pfurey89
- Mar 27, 2013
I have a Mojo, which is why I'm interested. Love the Mojo. Hate the Apple Connector + usb combo.
There's more of us seeing this behavior after the update, different chargers tested before and after. It might be intended like that, otherwise leaving it charging overnight would make it possible to wake up to a depleted Poly battery, as it stays on as long as it detects power input. As this is how it works, it's better to drain external power, not its own internal battery. At first it felt strange to me too, but now I think it makes sense! And the manual is already...outdated by now.I know it's boring, but I'm still perplexed by the charging behaviour of my MojoPoly. I'm using both 'intelligent' Anker 2.4A charger and 'dumb' Samsung 2A charger, and since the new firmware update, it seems to stick on white light. M-status light goes out as normal, but the P-status light just stays on white for hours (it could be permanent, but I end up unplugging it to use it eventually). Before the firmware update, it was going out when charged, which at least had the benefit of demonstrating that it had charged.
I'm not worried about it, but it is confusing, and it's not what the manual says should be happening. I suspect I'm not the only one with idiosyncratic behaviour, and I absolutely accept that it could be more to do with the chargers than the Poly. It would be good to get a bit more definitive guidance on the subject.
There's more of us
If I'm out and about, is there any other way to get my music without a SD card? I don't own music. I save offline in Tidal/Spotify. How do people get around this? I don't want to use third party apps besides Spotify/Tidal. I just want flexibility and don't want to kill sound quality.
@Feedbacker My Poly light stays white as well, but when I disconnect the charging cable the light flashes blue for a sec. This behavior didn't start until after the last firmware update. Before the update the Poly led would be solid Blue when finished charging.
Yes, the blue flash when disconnecting. I get that too.
I just think it would be good to have a visual indication of when the Poly is fully charged.
Yes, a full charge indication would be good, not sure how would that be possible though... But as for now it's better than before, we get a full battery after a night charge. We can estimate the time spent charging and we have the light color when unplugged from power, it's not that bad after all!Yes, the blue flash when disconnecting. I get that too.
Same here. Since the update, Poly was charging for around 10 hours without getting fully charged (as evident because of the white light); I ended up unplugging it and the light was blue ie fully charged.
The update may have influenced how it behaves when fully charged. At least I no longer see steady blue light meaning all charged as it goes out (pre-update, that is)
@Feedbacker +1 Agreed. I think the Blue light was the indicater that it is charged. The indicator was broken with the firmware update.
