NaiveSound
- Nov 8, 2015
Yes you can use Apple Air play.
Is there any way to do it over Android, avoiding Bluetooth?
I was one of the lucky beta testers and enjoy my Mojo/Poly for almost two month now. I guess it's time to come out and share impressions
Exiting news, can't wait to try the new features.
I will try to upload some pics of Bubbleupnp as App on my Android phone.
It works great in my home network and on the go. Streaming Tidal is as easy as it gets.
My review will still take a while since I was bound to a hospital bed the last weeks, but as a little sneak peak I can tell you that the convinience of using this 'Headless DAP` can not be valued enough.
I can understand that John was a little irritated by the one reviewer who would prefer a screen. Not only would it make Poly more expansive, I guess it would have made it a lot harder to achieve the impeccable EMI/RFI protection that Poly has to offer. I have not had one issue with EMI/RFI whatsoever. You can already tell I'm sold and I think most of you will be after testing this little marvel
Cheers
Mine is charging as we speak!
Cheers
Yes I've been live streaming Tidal and controlled SD playback via Bubbleupnp on Android. As long as you pump up the volume to max on the App you're using it should be bit perfect.
@NYanakiev
It's spelled out in the manual. You need to connect to the Poly wifi choose playback mode and assign it to your network.
Cheers
SO to clarify, not via the Tidal App, only via Bubble so therefore not offline stored files within Tidal.
If out & about with Mojopoly & phone and listening to Tidal it would constantly be pulling Tidal tracks over 4G using phones data allowance.
@NYanakiev
Is there one light illuminated or both?
If it's just the one saying M.status it means Mojo is loading, but not Poly
Cheers
Only P- the light is blue for a few seconds followed by green.
Its not the green blinking (I guess 3 times) right after you power it up? This indicates Poly checking the micro SD.
