Chord Electronics ☆ Poly ☆ (wireless & microSD module for Mojo) ☆★►USEFUL INFO on 1st PAGE!!◄★☆
Aug 19, 2024 at 5:12 AM Post #19,486 of 19,990
Normally I use poly over upnp and it works fine nearly all the time.
Sometimes though, it would be convenient to connect from another device directly via Bluetooth. I've tried 3 different phones and 2 computers and all say, "can't communicate with this device".
Does Bluetooth actually work on Poly? Is there something I'm doing wrong? Is there some gotcha that I need to know about?
Aug 19, 2024 at 6:17 AM Post #19,487 of 19,990
I guess you are trying to stream over Bluetooth from a music app or similar. That doesn’t work with poly as far as I know. You can connect via Bluetooth and control poly to play music from the SDCard and you can use it as an airplay device or stream over WiFi or use it as a Roon endpoint.
I may be wrong but this is the extent of how I can use Poly
Aug 19, 2024 at 8:17 AM Post #19,488 of 19,990
As far as I'm aware Poly only uses bluetooth to control the settings through GoFigure. You can't use it to stream, although as you can play playlists through GoFigure I guess that isn't strictly true. But surely nobody uses GoFigure for that?
Aug 19, 2024 at 8:54 AM Post #19,489 of 19,990
If you set Poly to Airplane/Bluetooth mode from GoFigure you can connect for bluetooth audio. Note that it only supports SBC codec.
Aug 19, 2024 at 6:04 PM Post #19,492 of 19,990
You can stream to the Poly via bluetooth
Aug 20, 2024 at 2:14 AM Post #19,493 of 19,990
To be honest de mojo2+poly is only okay for streaming over wifi or sd card.
Neither of any chord device supports bluetooth streaming LDAC or aptx HD or aptx lossless. It still not lossless but okay.
Maybe a poly2 or a mojo3 once?
What I have learned about chord products, don’t expect multi functionality like a ifi xds gryphon, or any other portable dac… if that is what you are looking for go somewhere else.
If it is extreme good sound quality, and willing to live with the cons, chord mojo2, hugo2 etc… are amazing portables, no competition
Aug 20, 2024 at 6:21 AM Post #19,495 of 19,990
Hi all
Had the Poly for a couple of months now. I've settled on using Mconnect to access Tidal and my Naim Uniti Core music server.
Am interested to know what the actual data flow in this scenario and hoped someone could confirm.
Am I correct in thinking that Mconnect requests a Tidal stream to be sent directly to the Poly and Mconnect remains in the loop for control but does not process the stream/file?
Many thanks
J
PS, did Rob W develop the Poly or just the Mojo?
Interesting question. I have always assumed that the source device receives the Tidal stream and then sends it to the Poly. What you describe sounds more like Tidal Connect (or Openhome) which Poly does not support... But I really don't know. Maybe others can chime in.
Aug 21, 2024 at 10:22 AM Post #19,496 of 19,990
Hi all
Many thanks
J
Only way to know for sure is start the stream and close Mconnect.
It would make little to no sense for the data stream to go to from DLNA server through MConnect to the poly. I makes more sense for MConnect to direct your server to the poly directly. That's how Roon works and IIRC how MConnect should work.
Aug 21, 2024 at 10:58 AM Post #19,497 of 19,990
I agree for files that are stored on the DLNA server (MConnect is controller only), but for Tidal it may be more complicated. I may play around later just out of curiosity.
Aug 21, 2024 at 11:26 AM Post #19,498 of 19,990
Well, that experiment didn't help explain anything.
Using mConnect on my iPad, playback stops on the Poly as soon as you close the app, regardless of whether it's Tidal, Minimserver DLNA server or even Poly's SD card...
Aug 21, 2024 at 12:50 PM Post #19,499 of 19,990
I am pretty sure roon resends all streams especially since one of it’s big features is dsp which needs the core. I have always felt mconnect does the same as it needed to do the first unfold of the mqa stream.
Aug 21, 2024 at 1:26 PM Post #19,500 of 19,990
The Roon core sends the streams to the Roon endpoints. The Roon remote software on iOS/Mac/etc... doesn't have the data stream pass through that device prior to streaming to the Roon endpoint. So, you can close the Roon remote on let's say your iPad and open Roon remote on your computer without interruption. The stream is going straight from the Roon core to the endpoint. This is regardless of using Qobuz, Tidal, etc...
MConnect is different. I'm pretty sure that if you are using DLNA from a DLNA server to DLNA endpoint, the stream goes from server to endpoint without going through MConnect itself. If you are using Tidal or Qobuz, MConnect is sending the data stream to your endpoint.
That's why in the OP case it's easy to answer his question. If he closes MConnect and the sound stops, the data stream goes through MConnect.
  • CH23
