Chord Electronics ☆ Poly ☆ (wireless & microSD module for Mojo) ☆★►USEFUL INFO on 1st PAGE!!◄★☆
Sep 18, 2024 at 6:22 PM Post #19,516 of 19,990
Not promoting mconnect, just saying the software now (approximately since one or two months) does not interrupt anymore the actual song completely after hitting Pause and later on Play again.
Has anyone noticed any glitches, quirks or other issues after updating on iOS 18 with the software or Poly?
BTW: late 80s Ministry albums are in the "mix" :wink:
And finally: Rio grande blood
Sep 19, 2024 at 4:20 AM Post #19,517 of 19,990
Stopped using mconnect all together, annoys me bigtime. Using wifi mconnect works, also with qobuz connect.
If I use iphone hotspot it refuses to see my poly, so can't use qobuz then. bought the software for nothing (useless)
Sep 19, 2024 at 4:31 AM Post #19,518 of 19,990
I'm using it on iPad Pro 2020, it's called "MConnect HD" then. So I didn't give full information, sorry. Maybe the iPhone-version differs from ipad's.
Sep 27, 2024 at 8:05 AM Post #19,520 of 19,990
Hi All, I am having iPhone AirPlay connectivity issue. I would like to know if anyone from this thread is experiencing the same.
I am using iPhone 13 Pro Max with latest iOS (v18). While I can see Poly as an audio output device but cannot connect Mojo2+Poly. iPhone UI seems connected but audio comes out of iPhone. Also Mojo2 LED is not red (I think red means AirPlay connected).
Tests done so far:
  • [Failed] iPhone 13 Pro Max (iOS 18) to Mojo2+Poly
  • [Failed] iPhone 13 Pro Max (Upgraded iOS to latest developer) to Mojo2+Poly
  • [Success] iPhone 13 Pro Max to Bose soundbar 700 via AirPlay
  • [Success] iPad Pro 2020 with iOS18 to Mojo2+Poly
Sep 27, 2024 at 12:13 PM Post #19,521 of 19,990
Tests done so far:
Further testing.
  • [Failed] Factory reset Mojo2+Poly
  • [Failed] iPhone thethering connection
Sep 27, 2024 at 2:03 PM Post #19,522 of 19,990
Further testing.
The LED on the Mojo2 is for sample rate, not specifically Airplay connected. Airplay is 16/44 sample rate and red on the Mojo2 signifies this.
If your iPad can Airplay to the mojo2/poly, the poly is working correctly. Others have had issues with iPhones, poly, and airplay. I recall seeing a recent post in this thread. It's likely the developer iOS that is your barrier. You can try mConnect to stream to the poly. IIRC, they have a free trial version.
Sep 27, 2024 at 6:16 PM Post #19,523 of 19,990
Tests done so far:
Do you have any wifi extenders at your house? They can mess up Airplay connectivity.
Sep 27, 2024 at 9:22 PM Post #19,524 of 19,990
Hi Daniel,
Thank you for your input.
Managed to fix this issue by iPhone Bluetooth on/off, changing iPhone WiFi privacy functionality.
It is indeed Mojo2 LED is for sample rate. I was also taking that as 'connected'. I was using generally available version of iOS and could not connect, so upgraded to developer.
Sep 27, 2024 at 9:24 PM Post #19,525 of 19,990
Hi Menkau,
As noted in other reply, managed to fix this issue by iPhone Bluetooth on/off, changing iPhone WiFi privacy functionality.
I have few mesh repeater. Other iOS devices are working fine so it was not my case.
Oct 4, 2024 at 11:38 AM Post #19,527 of 19,990
Got mojo 2 recently and want to get a 3d printed case made for it. If anyone have files for the case if mojo 2 please share them that would be helpful.
There is a good case on this thread for Mojo2Poly. I used the design from @surfgeorge (if I recall correctly ). Not sure about Mojo on its own, but I assume that it’s for both based on this thread being a Poly thread.
Oct 11, 2024 at 1:25 AM Post #19,529 of 19,990
Hi,
I have bought a Poly used. The former owner was a elderly man and he had used it like 5 times, so it looks brand new.
I have a huge problem with it. I won't show up and connect to the Go Figure app. I have restarted my phone, toogle bluetooth on/off, reinstalled the app several times, I have location turned on, both Mojo 2 and Poly are fully charged. I even tried to connect another bluetooth device to my phone (iPhone 14) to make that it worked, and it did. With the configuration button I did a factory reset and also got the information that my firmware is 2.0.0.
I was so looking forward to this device...any idea what's wrong?
Oct 11, 2024 at 4:35 AM Post #19,530 of 19,990
Hi,
Go to bluetooth settings and connect the poly manually, after that start the app again (first really shutdown the app, so it is removed from the phones memory)
I love the poly+mscaler but it is a quircky device… once it all works, it is just fine
