Chord Electronics ☆ Poly ☆ (wireless & microSD module for Mojo) ☆★►USEFUL INFO on 1st PAGE!!◄★☆
May 22, 2024 at 12:36 PM Post #18,886 of 19,170
Am I the only one who has this message, since a few days ago, whenever I try to update the firmware in Gofigure?
And would it be possible that my inability to find my sd card on 8Player and Mconnect, while it appears on Rigelian, would be related to the fact that I cannot make an update since 3.2.0 (the firmware that there is on the Poly since I received it last week). Any link too with the fact that I can't find Qobuz on Rigelian (I have to use Mconnect for Qobuz, then Rigelian to play music from SD Card) and both playback very laggy when it comes to changing tracks?
I have 7 days left before I decide to keep it or not...
I'm having the same. This is a new error for me as compared to a couple days ago though. Before I would be allowed to attempt the firmware update and it would have this same popup but would say "Device Disconnected". I'm on 3.0.0.
May 22, 2024 at 9:13 PM Post #18,888 of 19,170
I just got my new Poly from Moon Audio and had no trouble setting it up. However checking for firmware update did not work (msg says no servers available). For what is worth it came with 3.2.4 installed.
Listening to Apple Music dowloaded 192 Khz hires album now but it's only playing at CD resolution via Poly (it does play at full resolution when using USB-c cable from phone to Mojo 2). From what I read this is expected but still wanted to check here - Apple Music can't play higher than CD resolution via Poly?
May 22, 2024 at 9:45 PM Post #18,889 of 19,170
That's the limit for Airplay (max 16/44.1) - not just for Poly.
May 23, 2024 at 11:17 AM Post #18,890 of 19,170
Thanks for confirming. Even though everything is working fine with Airplay I tried Poly in hot spot MPD mode and that is on another level of amazing - full resolution with simple playback of files/folders from 1.5TB SD card which pretty much holds my full library is definitely the way to go for best possible sound out of this rig. Both MPD and MaximumMPD ios apps work fine as far as I'm concerned.
May 23, 2024 at 12:51 PM Post #18,891 of 19,170
Is it normal that outside, in hotspot mode, with iPhone connected to Poly via Bluetooth, nothing appear in 8player, Mconnect and Rigelian? I can’t even play music from SD Card.
Even at home with WiFi SD Card doesn’t appear on those apps (except Rigelian).
And is it normal that I can’t connect to Poly which appear in my IPhone wifi network? It seems that it’s trying to connect endlessly.
It’s a real pain to set up.
I’m sorry to bother you with that, I must be the hundred person who ask for these basics. I’m leaving for a week trip tomorrow and I’d like to be able to listen to music… 800€ ouch!
May 23, 2024 at 12:57 PM Post #18,892 of 19,170
My understaning is that you would want to connect your phone to Poly (in Poly hotspot mode) by connecting to Poly's wifi network (not via bluetooth). Regarding your other question are both Poly and iphone on the same 2.4Ghz network? If not (ie phone is on 5Ghz) then it won't work.
May 23, 2024 at 1:06 PM Post #18,893 of 19,170
Also, maybe try MPD and MaximumMPD apps to access SD card (instead of 8player and mconnect - I could not get those to work either). But MPD and MaximumMPD both work for me and I don't feel like I need to pay for Rigelian even though I'm sure it's probably nice with additional features since a lot of people in this thread seam to like it. In my opinion the biggest upgrade Poly could get would be for Apple to release Airplay for higher resolutions (i.e. up to 192Khz would be awesome). They I would just use Apple music for everything and not have to mess around with different modes etc (except when traveling when there is no wifi it is awesome to be able to play via MPD from SD card).
May 24, 2024 at 8:01 AM Post #18,894 of 19,170
I just decided to re-purchase Mojo2Poly from a fellow head-fier here on this site. I will use it as a streaming dac permanently connected to my Jotunheim 2 powering Dan Clark E3.
My home wifi is 2.4/5ghz combined. I am using Tidal on an iPhone 13. Cd-quality via Airplay is plenty fine for me.
Will the iPhone+Poly be able to connect automatically via Airplay even though they might be on different frequencies? I suspect my iPhone to run on 5ghz and Poly is capped at 2.4. Will the iPhone be able to recognise Poly on 2.4 and then switch over to that frequency by itself? I would of course prefer not needing to fiddle with my wifi config and set up another network with the sole purpose of being able to stream to Poly.
May 24, 2024 at 8:12 AM Post #18,895 of 19,170
No issues with devices on different frequency. As long as you are on the same network SSID, all will be fine.
May 25, 2024 at 10:52 AM Post #18,897 of 19,170
This is probably a question that has just been answered and been answered before but if I may ask, just in case I am mistaken….
**** Am i right to think there is NO WAY to play QOBUZ (or tidal) music from an iPhone or ipad to the chord poly in HI RES whatsoever in any way, shape or form? (Eg using home wifi, or anything else) ***
I have owned the poly for a while but only bring it out every now and then so when I wonder this, after a few google searches, I usually give up on trying to get hi res come through so I thought I’d check here tonight to end this question so that it does not bug me again.
I appreciate being put out of my misery (again apologies if this has been answered before - but I am tired of googling this question and still being unsure of this and not being confident to lay this idea to bed)
Many thanks
Peter t
May 25, 2024 at 11:22 AM Post #18,898 of 19,170
Many thanks
Peter t
I'm sorry you didn't find anything, but streaming in hi-res to the Poly with qobuz/tidal (above 16 bit/ 44.1 kHz) there's no problem, for that I use mConnect. I'm pretty sure this is possible also with our apps. Others would correct me if I'm wrong (I'm pretty sure I'm not!). The information is readable on the lower left of the application.
But if the files you want to play are physically located on your iPhone/iPad, that would only be possible with AirPlay, 16/44.1.
May 25, 2024 at 11:44 AM Post #18,899 of 19,170
mConnect works well. There are also Roon and Audirvana ($$$). If you add Openhome support (with BubbleUPnP Server), you can also use a few other apps, such as Linn, etc.
May 25, 2024 at 12:29 PM Post #18,900 of 19,170
Looks to me that the update server that Chord use, has an expired SSL cert. When I browse device settings on my Poly, my AV (Bitdefender) flags this URL as insecure : https://chordupdates.co.uk
