Chord Electronics ☆ Poly ☆ (wireless & microSD module for Mojo) ☆★►USEFUL INFO on 1st PAGE!!◄★☆
Jun 8, 2023 at 4:42 PM Post #17,866 of 19,952
Partly. To clarify: I just want to use up my remaining two days m2-free trial-append a my poly packaging still consisting 90 day free trial and after that 90-day-period stay with qobuz (paying till I die).
Priority number one is not throwing away that 90-day-poly-present and priority number two is preserving all my favorites without changing registration/Email address. So saving money without changing registration/Email address. Is that possible? Thanks!
Someone else will have to advise.
Jun 8, 2023 at 4:55 PM Post #17,867 of 19,952
Very likely I explain too complicated. Using both free trials with just one registration/email-address. I'll just try it out.
Jun 8, 2023 at 7:55 PM Post #17,868 of 19,952
Not sure about continuing free trial on the same account but an easy work around is to use Soundiiz after creating a new account to transfer over your playlists.
Make a new Qobuz account and activate 90 day free trial from Poly > Use Soundiiz and just do an instant transfer of playlists (a music management application that can connect all your accounts from different services including Qobuz) > Listen via the second account until expiry before finally going back to paid membership on whichever account you would like to keep using.
Jun 9, 2023 at 4:43 AM Post #17,869 of 19,952
"Not sure about continuing free trial on the same account…" describes perfectly what I was thinking about..
I will go with your proposed soundiiz-way. Still have old tidal lists, have to preserve them anyway.
Last but not least, this increases the value of an already great pair of devices from Chord…
Thanks!
Jun 12, 2023 at 2:34 AM Post #17,870 of 19,952
Listed Poly in classifieds if someone is considering getting one…… ;).
Jun 12, 2023 at 4:03 AM Post #17,871 of 19,952
Jun 12, 2023 at 4:17 AM Post #17,872 of 19,952
Could you share the reason..?
Sure, as also explained in my classifieds listing: I added Poly for ROON streaming but as I now have a ROON Certified DAP I'm only keeping Mojo 2.
Jun 13, 2023 at 7:56 PM Post #17,873 of 19,952
Hello,
I have not used chord mojo2 with poly in awhile. I have new android phone samsung s23 ultra and go figure finds my poly 2 successfully but will not connect to wifi....I can get poly to work only when poly in hotspot mode.......is there a reason it cannot connect via wifi to my phone if my phone is in hotspot mode
Jun 14, 2023 at 8:18 PM Post #17,874 of 19,952
I recently purchased a Poly for my Mojo2. I bought a microSD card and populated it with DSD music. I added two albums total. The music comes with a jpeg cover.
One shows up and the other not.
I am using mconnect and it works great. Unfortunately I can't get the music on the SD card to show on the Gofigure application only on the mconnect.
Does anyone have suggestions for these two problems please?
Jun 14, 2023 at 8:23 PM Post #17,875 of 19,952
GoFigure only shows playlists (playlists exist in .m3u file format) , you must create a playlist using a different app (mconnect should be able to do this I believe) and add the albums/tracks to the playlist. Additionally, GoFigure can ONLY see the playlist (.m3u) but not open it up and view the actual tracks or albums placed in it, so you can't select individual tracks unless you create a playlist for each individual track separately. Everything can be easily managed on a Windows PC if you know what you are doing.
Jun 14, 2023 at 9:10 PM Post #17,876 of 19,952
Thanks - I will just use mconnect instead of gofigure. If only I can figure out why my art work for one album does not appear on mconnect.
Jun 15, 2023 at 3:52 AM Post #17,877 of 19,952
Hi All,
I think I figured out how to play non-English songs, since the app is stupid and only supports ISO 8859-1.
The UI supports UTF-8, but it uses ISO8859-1 to read files.
Here is my solution. I play songs on airplane mode.
I prefer to use Visual Studio Code to do the job.
1. Create a m3u file. (I think you use UTF-8).
2. Paste the Relative path into the file.
3. Save the file to ISO8859-1.
4. You would see a lot of '?'. It's correct because Poly read the UTF-8 file to this.
5. Insert the SD card to your Poly.
How to create non-English m3u files.
1. Convert non-English text to ISO8859-1
黃綠色社會 - Actor (UTF-8)
to
é»ç¶ è²ç¤¾æ - Actor (ISO8859-1)
2. Weird text, but it's TRUE.
Jun 16, 2023 at 3:45 PM Post #17,878 of 19,952
Did gofigure playlist generator for poly ever get launched. Haven't used mine for a longtime
Jun 21, 2023 at 9:42 PM Post #17,880 of 19,952
@Noonanstein nope. GoFigure is dead app, except for basic features. I am learning Glider and have Rigelian standing by. Other non-iOS options exist.
Chord released a minor upgrade to GoFigure 2 days ago “to support poly firmware changes.” Maybe I’m overly optimistic, but it looks like Chord has not given up on Go Figure, and it sounds like a firmware update to Poly may be on its way.
