If your Poly is still on 1.0.x then you will have to manually update several firmware versions (using the pin to 1.41?) before you can use GoFigure to automatically update to 2.0 etc.
I only ever had to perform one update using the pin (to get the firmware from 1.26 to 1.41?) but I did find that Poly did seem to have a mind of its own when updating.
Probably your first step should be to clarify which version of the firmware you are using:
- If you plug your headphones into Mojo, and then try using the Poly pin, you should be able to hear Poly describing basic info about which firmware version you have, and which menu option to select.
- I think there was also the option to use a PC or phone/tablet browser to identify the firmware, but I cannot remember the URL
Anyway, if you can identify the firmware version, you will then be able to identify how many firmware updates you have to perform, before you can 'ditch the pin'.
There is a lot of info in the official
FAQ
plus owners able to offer advice in this thread.
