Have you tried instrumental music like piano over airplay? You can clearly hear LP static like sound while the piano plays.
just curious because I don’t believe it’s a hardware issue.
Will give it a go
Well, Roon uses their own protocol instead of UPnP if I remember correctly. Just because it works with Roon their own protocol (it is RAAT or something like that), does not mean the 2GO has no issues with other protocols.
It is actually quite an achievement to mess Airplay up considering Airplay implementations are certified and are generally robust.
And I am not going to pay $700 for a music player to make the 2GO work like it is intended to be. Especially since it is a portable DAC and I cannot run Roon on my phone.
Yes Chord do watch this thread, and answer questions quite often, for example https://www.head-fi.org/threads/cho...-adaptor-official-thread.925464/post-15607868I am thinking/hoping that Chord is watching this thread and I would bet these issues with AirPlay and connectivity are fixed in a future firmware update. My current firmware is 0.9.1 ... this device is still not at 1.0 or later.
Charging with 2go is really HOT!! At first time I just thinking is there any problem about the battery? I know charging battery will be hot, just like charging phone, but not that kind of !! The case will even prohibit the heat dissipation, so I will skip the case too. Maybe i will consider purchase a loose bag for 2go + Hugo2, after major issues have been fixed.
The LS50 Wireless was and has been a complete sh!tshow (just read their reviews on app store), and now Chord can't make a $1300 product work. I guess the real question is, does any network/wifi related equipment made by these hifi companies work?
I've recently been using this "laptop vacuum" thingy to cool down the hugo2go during charging. It sucks hot air from the rca/coax/3.5/6.5 jack. Works like a charm!
https://www.amazon.com/Temperature-Auto-Temp-Detection-2600-5000RPM-Nintendo/dp/B01NACVLWM/
Yes I watch the thread and note the comments but I don't always have the time to respond!The question I was answering in the post you quoted my reply from was “What functions of the 2go are working hiccup free?”
To be very specific (and I thought was obvious), I believe Roon is working hiccup free. Roon uses RaaT.
Like I said in my previous detailed post with bullets on the page 149, yes, I agree, AirPlay is an issue.
As advertised, apparently! Was that WiFi or wired?I just tested the Hugo2/2Go combo battery life using Roon Live Radio the whole time through earphones and got about 8 hours.
Good point. WiredAs advertised, apparently! Was that WiFi or wired?
Doody
I have Node 2i which has worked flawlessly and constantly on, the BluOS is also very good, 2nd to only Roon.......whish Chord could use their software....one can only dream.....The LS50 Wireless was and has been a complete sh!tshow (just read their reviews on app store), and now Chord can't make a $1300 product work. I guess the real question is, does any network/wifi related equipment made by these hifi companies work?
I am sure they are, but there is no point using them with a Chord DAC as they will undo all of Rob's hard work, by reconverting the analogue to digital and processing it through their internal DAC.I had the KEF LS50 Wireless for over a year. Amazing speakers.
