Matt,
Yes, I‘m only tagging the tracks with album, artist Infomation and the cover art.
For upsamping tracks to PCM768KHz, you can use an evaluation copy of HQPlayer Pro. You can download it here:
https://www.signalyst.com/professional.html
Try it with polysinc-long-lp filter and LNS15 noise shaper.
When I switch tracks there is burst of squealing noise as the sample rate light flashes red. While the tracks are playing the indicator shows light purple as expected. However, if I pause a playing track it remains light purple but I will get the squealing noise until I resume play or start a new track.
Thanks so much for the instructions on JRiver. I‘ll give it a try.
One more quick question if I may. It would improve the 2Go experience a lot if both SD cards were accessible simultaneously instead of having to switch to GoFigure and change cards every time I want to play s song from the other card. Is this possible and on the road map for development? If not I‘m going to have to bite the bullet and buy another 1Tb card. However, they are still quite expensive.
I do hope you know that for all our grousing about glitches, we love this thing!
All the best to you.
