B8 (IMHO) is better than B&O H6, Sennheiser Momentum 2 Over Ear, Sony MDR-Z7, Denon D7200, Audio-Technica ATH-ESW9.
In the giant-beater category it's second only to Takstar Pro 82/GM200.
LOL!
You might want to describe your criteria for "the best".If my budget is 300 us dollars and I want a chifi headphone. Is the BossHiFi B8 then still the best option?
If so where should I buy it. If a random Ali express seller sends it, I might need to pay customs.
Sound quality wise driven by a mobile phone.You might want to describe your criteria for "the best".
What sound signature are you looking for?Sound quality wise driven by a mobile phone.
I don't mind using a Bluetooth headphone, but a wired headphone like the B8 is not a problem either.
I listen mostly to pop, rap and acoustic music. Sound signature, neutral. I don't like an overly bass headset. I currently use an iem cuz it is handy.What sound signature are you looking for?
What kind of music you enjoy most?
Since you have a 300$ budget, the solution is very simple:I listen mostly to pop, rap and acoustic music. Sound signature, neutral. I don't like an overly bass headset. I currently use an iem cuz it is handy.
Somehow I feel that an overhead headphone provides me more detail.
Thanks for the info.Since you have a 300$ budget, the solution is very simple:
1) Pro 82 v2 at 62$ - https://www.aliexpress.com/item/32808454492.html
2) Bosshifi B8 at 62$ (68$ minus 6$ coupon) - https://www.aliexpress.com/item/32944382637.html
3) Shanling Up2 at 79$ - https://www.aliexpress.com/item/4000008394295.html
That's a total of 203$, plus you can use a "5$ off 99" store coupon when ordering Pro 82 and Up2 together - so now it's 198$.
Pro 82 and B8 compliment each other very nicely - you will like some music better on one, and some on the other.
Up2 will allow you to drive both of them adequately - both from smartphone (over Bluetooth) and laptop/PC (over USB).
Just don't use Bluetooth with your laptop/PC - they don't support advanced codecs.
To make the headphones easier to use over Bluetooth, you can buy shorter cables.
This 4$ cable works great with Pro 82 - https://www.aliexpress.com/item/32798495447.html
Shouldn't be too hard to find a short cable for B8 either - any 3.5mm to 3.5mm with narrow plug should fit.
Buying 2 headsets and an amp is not really what I had in mind, but at least it verifies that the pro82 or the B8 are the best that fits my budget.
Closed.Fwiw the Pro82 is one of my biggest disappointments in full size headphones. The lack of dynamics in them makes them very two dimensional and boring sounding. I tend to find something good in pretty much every pair of headphones cheap or expensive, but the Pro82 is a rare exception unfortunately. As always YMMV.
Are you looking for closed headphones or are open ones also an alternative?
1more triple driver
Closed.
I want to use them in my office. Open headphones leaks too much and will result into complains.
I have read positive things about the 1more triple driver. But that looks like an open model.
Back in the days I read lots of positive stories about the pm-3, but it is hard to find in the Netherlands. And it needed to be driven by a powerful source.
I'm reading up about the Shanning UP2 that @BenF recommended. I wasn't aware that bt amps existed, they might solve that power problem.
For $300 the Meze 99 Classic are a highly regarded option.
There's a color variation called the Massdrop X Meze 99 Noir that is $200:
https://drop.com/buy/massdrop-x-meze-99-noir-closed-back-headphones
