JayGold
Oh it does seem quite niceLZ A6 mini would be the best I think.
But i cant find it on amazon
I take id have to order from ali? Or is it just hard to find?
Aliexpress, penon audio seems to be the only places to get them from.Oh it does seem quite nice
I bet it would be the Tri I3 ( just a guess, havent heard them)Ok... I’m caught between two options, either one is financially possible and waiting for trigger to be pulled.
Which sounds better: Fearless S4 or TRI I3 ?
If you’ve heard them tell me which sounds better to you please?
(No worries, all good, shout one out!)
I have the Tri i3 and is very good, unfortunately I don't know the other.Ok... I’m caught between two options, either one is financially possible and waiting for trigger to be pulled.
I have the TRI I3 and a few levels up the S8f (and had the S6rui). In general, save some money and get the I3 unless you're really into imaging, them the S8f might have an edge..... So I'm going to guess I would suggest the I3 against the S4, though I've not heard it, just it's big brothers.Ok... I’m caught between two options, either one is financially possible and waiting for trigger to be pulled.
oh no, the destroyer is coming to you, buy buy all your dynamic driversWell since linsoul got the Urbanfun iss014 and my voyager 3 hasnt been sent out yet, I also bought the iss014. Lets see how much longer it takes for them to make the voyager 3 it has almost been 2 months already....
