Otto Motor
NiceHCK NX7 Pro up now on Head-Fi: https://www.head-fi.org/showcase/nicehck-nx7-pro.24064/reviews#item-review-23311
How about the Jade Audio EA3 for a more budget oriented buy. They are great for games and movies alike, being bright sounding, while having good sub-bass. And with a cable swap, (with a copper one) they do music well too. Their strong point being soundstage. Although if you are treble sensetive it might not be for you.
Anyone have recommendations for a set (preferrably under $100) that provides good details in the upper-range, thicker mid-range, bass that hits hard with some decay but no boominess or bleed. (QDC Anole VX, UM Mest, A64 18s come to mind). I ordered a BGVP SGZ-DN1s and was actually blown away by this $29 set. I just wish it were thicker (sounded thin) and had more bass and better detailing in the upper-range.
I would like to stick with a hybrid setup while i think only DD are fine they always miss things for me in the upper range.
I have on order the NICEHCK NX7 Pro and it seems to hit just about everything (minus the potential treble spike and mid range) but we'll have to see.
if you are treblehead or have a little bit soul of it, you will be pleased with NX7 Pro, they like downgrade version of Andromeda, while chasing similar treble presentation. The silver filter is the best balance for me, but i added cut of sponge inside the filter to made them smoother in highs. Upper range details definitely have great extension and details but can be double edged sword to person that treble sensitive, but for me (im a little bit treble sensitive actually) the silver filter is safe, moreover with that foam added. mid range isn't thin and have good timbre. technicalities is very good, with good soundstage, but soundstage isn't their main strength.
Bass is tight and fast, the CNT driver is well tuned here. I like the speed, texture and control. very minimal smearing.
Thank you for that insight. I do enjoy treble. I have tinnitus but my ears seem to be finnicky when it comes to treble. Sets that one wouldnt expect to "excite" my ears, do and sets that are bright - don't. I am very much looking forward to this pair and now you have me excited.
Ostry tips will be your friend if ever needed. They have a treble filter. You can take them out and stick them into your own tips too.
Thank you for this. I see you everywhere. So knowledgeable
Hi @Slater @SiggyFraud
I'm checking with my friend to see if they can ship to you (USA & Other places besides Asia) will update once I get a reply
@SiggyFraud @Slater heres the link at Aliexpress, but I believe you have to add a note to remind them for the new batches, maybe attached the image just in caseThey have also changed the box to reflect the new improvements, but sadly you need to indicate to the seller in order to get the new batches, see photo for the differences in packaging
I suppose this wasn't your review?@SiggyFraud @Slater heres the link at Aliexpress, but I believe you have to add a note to remind them for the new batches, maybe attached the image just in case
https://www.aliexpress.com/item/4000110288546.html?spm=2114.12010615.8148356.55.2d651ed9l9bY6a
haha I just noticed that..that guy's from Ukraine (his flag) not me of course ..but it's pretty obvious its authentic..as I have made multiple purchases from their asian storesI suppose this wasn't your review?
Anyway, thanks for the information. Might check it out anyway.
OS100: LF less, dental correction Medium
OS200: low volume foot, dental correction stronger
OS300: low-frequency volume, tone correction strong teeth
Features:
1 .It is relatively common silicone plugs, OSTRY tuning plugs series can weaken the tooth varying degrees of tone, reduce high frequency spikes, eliminate harsh and so is not the sense of hearing.
2 .low-frequency trends in the overall frequency response curve, OSTRY plug can effectively uplift the low-frequency tuning than the column, enhance sense of atmosphere, and enhance patient degrees.
3 .In OSTRY tuning plug series, weaken the tooth and uplift low-frequency sound, followed OS300> OS200> OS100
PS: weaken the ability of the stronger dental tuning plugs, transparent sense it worse. Both can not have both. So transparent sense OS100> OS200> OS300
I wonder if the ostry 300 ear tips would help with the 14k peak with the NX7 (non-Pro)
