Nimweth
Hello and thank you! My review of the TRI i4 (unmodofied) is in this thread #25400.I look forward to a little review in the near future.
Quite interested in these iems. And value your opinion.
Couldn't get a good fit. The angled connectors forced the IEMs out of my ears and the supplied tips were useless for me.
I am happily using the stock cable on my Blon. What is the problem?
I am using the stock cable on the CMT1 also. What do you mean when you say it died? Suddenly there was no music for no reason?
Stock tips are crap.Couldn't get a good fit. The angled connectors forced the IEMs out of my ears and the supplied tips were useless for me.
Yes, they look cool but are pathetic for getting a seal. The BLONs are very good, no real criticisms once the fit is sorted out.Stock tips are crap.
I use the Starline ones on my Blon and i enjoy them a lot. I think they're terrific.
Gonna replace my cable as well, i hate it.
Left channel drop out. Then right channel. Then both. Sounding fantastic. Then rubbish. Then a channel dropped and didn't come back. Changed the cable and all is fine. Just picked the cable up to move it and one of the MMCx plugs fell off. Yep. I got a fairly poorly made cable
That's right. I had the same problem with the Whizzer A15 Pro. The connectors rotated as well which exacerbated the problem.Just another example of different ear anatomy. The angle works for me but I know what you mean. Some over ear cables cause that problem for me..
Well i have been looking at the TFZ no.3 alot, looks nice, great tech. Many people seem too like them. Good for the music i listen too And i belive it is a good secondary iem for the Tin audio p1 so i can change it up with those when i want a fun and easy going iem. Hmm.
But the Toneking looks great, i like dynamic drivers, but i also want too try a Balanced amarture one, but are those more prone too fatigue? Or is it in the tuning? Dont need razy amount of low end anyways, cause i undertand that most BA ones dont do that well, hmm. So many options i have been looking at so many these last days. My head is spoinning around.
Like i was set on the Tanjin Oxygen ones, then i read about the fit problem.
Thanks for the answer gonna look more into these.
If you'd like to try a single BA the KBEAR F1 perform way above its price imo. No worries for fatigue with those.
My favorite pair of IEM's these days are the LZ A6. They can be too energetic for some with some of the filter options but they can also be absolutely wonderful with others.
And btw. Those **** **** looks too good for the asking price on Alixpress, cant hurt too try them out for that price. HAh, that tech for that amount hmm.
Hmm...
Magosi DQ4 for $132. Damn. I might have to do that.
For a semi basshead. Is there good extension? Hip hop and such still sound good?
