Slater
They are pretty good, aren't they?
I got them few months ago and I wrote a couple of lines in the chi-fi thread.
They are quite bassy, but that can be fixed with little tip rolling. I settled for shallow wide bore tips pushed over the body of the iems so the nozzle is in line with the tip opening.
Very clean and smooth treble and mids, though.
Nice, I must have missed your post.
Great pic too - shows just how small these are.
For even better sound, remove those little white nozzle filters with a sewing needle, and just run it open! You can always put them back if you want.
I’m using the stock tips, but I will definitely try out your wide bore tip recommendation.
I’m also going to play with the rear vent (under the shell by the wire strain). A simple strip of micropore tape over the vent should knock down that low end. These have the opportunity to be amazing with just a touch less low end (which would make a nice balance of all frequencies).
