Time after time I tell myself to stop buying hybrid IEMs. I just don't like them. BA always sounds harsh and lifeless.
You should try Brainwavz BA range, B150 and B200 are far from harsh and lifeless
Just like with Magaosi BK50 recently. Good IEM, solid build and nice looking (a bit bulky though so not easiest to fit properly), high quality MMCX cable in the package (really heavy though, definitely not for sport). Bass is not deep enough to my taste and highs are harsh (not eardrum crushing Yersen FEN-2000 type harsh but still piercing).
Hmm, unless the build and signature changed when they made it detachable the BK50 is very light and it's bass hits very decent depth and the highs are smooth (maybe a bit dry with the wrong tips). BK50 is still one of the most open earphones I've listened to. You should use either Spinfits or a smaller Comply foam... makes big difference.
To further prove my point, yesterday Artiste DC 1 arrived (double dynamic driver inside). Holy ****, these are amazing. Bass is deeeeeeep. Sound is smooooth. Only lightly V-shaped. Detalisation is superb but with absolutely no sibilance in treble! Soundstage is pretty good (not the best but most certainly above average). Good fit.
Soundstage is bigger with Spinfits. opens them up further and pumps in a bi more air
