1clearhead
- Apr 5, 2013
Yes, they definitely have good looks...Yes, that is the GGMM C700 in silver which is what I have. Also comes in blue, black, or rose gold.
Very simple elegant style.
Hi,
I just received my IEM today that looks very similar to the Simgot EN700 but has a 9 instead of a 7, that I won't name because I like having a Head-fi account.
I immediately noticed that they have an unbearable amount of silibance. It could just be me, and I have been listening to the same single IEM for a year and a half (Somic V4.) I put it through the sine wave track and it has one ENORMOUS peak at 4500hz and a pretty bad one at about 10000hz. I've had them 'burning in' on white noise for about 12 hours now, it might have improved a bit but I can't deal with it, even if the bass and general detail stomps my Somic V4. Is there anything I can do? Mods and tuning? More burn in? Maybe I just need to get use to it. Even the EQ of my dap and laptop isn't getting it under control. Cable replacement? Maybe they are defective? Don't take my word for it though I'm sure they are very good.
What are some good Tips that reduce silibance? Comply? KZ? Thanks.
I've never heard of Neutralizer til now, and actually I was going to dismiss it but saw a positive review by a certain user whom I really respect so I might try it out, although I remain highly skeptical.Time to get an LG V20 and Neutralizer
I'm very glad I didn't get those. I was tempted, but after reading a few reviews I was like "ehhhhh, I'm going to wait until some more people get that because that lower treble peak coupled with the sibilance doesn't sound like my cup of tea."
So, the Z5000 turned out to be both really impressive and really disappointing at the same time. The last time I was this disappointed was I believe when I got my RHA MA750.
Oh, well, back to my ZS3.
Maybe I should give the KZ ZSR a try. Or the Tiandirenhe TD08. Or the UiiSii CM5. Or maybe the Rose Aurora, although that one is on the pricey side, but it does look promising.
Hi,
oh, I actually really like the look of them. The comfort is 10/10, I know it looks unintuitive, but they are super super comfortable.Almost got them due to some discounted offer. Tried foams on them? I can't stomach the design though, worried about the comfort.
I think I'm a basshead. A lot of signs point to "yes". However, I'm perfectly satisfied with both the CAL! (being my favorite) and the DT 770 Pro, neither of which is considered a basshead pair of headphones, unless I've missed something. The only basshead pair of headphones I own is the V-Moda Crossfade M-100 (got it used). I like it, but it too has some bass bleed, a.k.a. a wider range of lower frequencies was boosted than I would have preferred.You're a basshead but got the MA750? lol, that's gotta hurt. The sparkle was amazing up top though.
If you want a warmer, more musical sound-sig, the Tin Audio T1 is quite good too, I preferred it to the T2.
This is gonna get rant-y...
And yes, it did hurt. I respect the MA750 for what it is: bright-ish but very rarely sibilant, and with smooth presentation and decent detail. However, for me it was almost bass-light. Soooo many people were (and still are?) calling it bassy, saying it had great low-end, etc. So I fell for the hype, and bought them.
I still think that the award for the largest discrepancy between reviews/opinions and reality goes to the MA750. Every single pair of head/earphones that I've purchased has been in the ballpark as far as reviews go. I could see why a reviewer would call a pair detailed or not detailed enough, or sibilant, etc. Even if my experience was different, I at least understood why a reviewer would reach to his/her conclusion. With the MA750 there is no way I would ever refer to it as bassy. Unless "bassy" means "not completely devoid of lower frequencies". Then yes, it's bassy. However "bassy" in my mind means, well, you know... with at least a noticeable bump somewhere in the bass. The MA750 are at best bass-neutral to me.
Regarding the Tin Audio T1, it was on my list but got the impression that while decent it probably won't have the necessary low-end. I'll look into the T1 again, though.
So many choices. Should I just get a bank loan, and order all of them?
Not sure if you noticed, but I did get that one, and I was disappointed. While it does have an amazing extension and good punch, it also has a lot of bass bleed. The bass range that received a boost with the Z5000 is much too wide for my taste. The ZS3 sounds better to me, less extension on both ends, but overall smoother and more enjoyable.a few IEMs that I remember as having good low-ends being discussed recently is maybe the Z5000
A similar one to the Einsear T2 is the Urbanfun Hybrid. I say this because I have both.I'm about to buy the Einsear T2. I'll mostly use it for walking to work, or when i hit up the grocery store. So very casual use, and a real budget price. Anything else to consider before i purchase? I need it to have a mic and not be ugly as well.
I also did the excellent Slater Mod on the ZS3, removing the foam and taking off the red grills. Then I tested it and found the tambourine on "Shaft Theme" to be harsh. This was tested against the UrbanFun Hybrids, where it sounded really good.Edit: On a side note, I did the ZS3 mod partially.
If you prefer a warmer sound signature and elevated bass along with relaxed treble, the KZ Es4 might be a good choice. Another option to look at is the TRN V20.I've never heard of Neutralizer til now, and actually I was going to dismiss it but saw a positive review by a certain user whom I really respect so I might try it out, although I remain highly skeptical.
But a new phone? Is there a reason to recommend changing my phone? I'm confused now.
Edit: On a side note, I did the ZS3 mod partially. I removed the black foam-y thing from the canal but left the red filters.
I feel it improved the clarity and highs a tad. Would have to listen to it more, though.
Hi,
