Well
@Slater i searched micropore mod and i saw your name....the xiaomi in pro HD...
I didn't know you did it well.....hahaha
And well i m back after the phillips shl3300 mod
After a long time
I am gonna review TinAudio T2 modded
Well, music i review here scabourogh fair from anime shimatsu nani in lossless
Low end- i was able to feel organ pipes harmonic.....it is at 12Hz as per scientist speak of. It is frequency coherent bass rumble in some of the best song which make the song smooth in transition and full in body. Bass heavy iem organ pipes get resonanted making everything congested in slow song...
But it was perfect here. Well on par to shure 846cl.
What we call true subwoofer response and not some crappy bass. Subwoofer response means that it makes you feel song while remaining flat(well U shape rather than V). Bass rises from 38Hz here rather than 400Hz on some bass iem. Shure rises from 22Hz. It roll of at 5Hz slowly and steeply from 2Hz to inaudible 1Hz.
Bass- tight as it can go, little slower than BA driver. Its like dual piston magnet woofer. It gives well texture and it is a little boosted (2dB) from range. It gives me a full sound feeling and give a sense of bass depth. Shure is only 1dB boosted but is flater and faster.
Mids- love, love and love. Shure is recessed by 2dB to give bass some emphases, not here. This is true electrostatic style mid, fast as it can possibly can. Perftect PRaT(pace, rhythm and timing).
Treble- well smooth, something between ex1000 and mdr 7550 but with a resolution. Tending toward ex1000 but sounds comfortable with bad sources
Soundstage- way bigger than Havi B3 mk1 and kz zs5v1. Rounded stage, equal width, height and depth but lacks too the hologhraphic shure 846. Well by 30% to my ears.
Soundscape- not mentioned commonly in headphone or iem review, well you can listen to binaural recording and get sounds above your head. I would say dobly atmos passed and not jh layla 2 score nearby. T2 mod gives huge 360 degree sound but still lack to jh audio layla but smashed shure out of party.
Image: good, well in 300$ iem realm but micropore hollows up the treble a bit. So it is like mee audio p1 sort. Well better, its not super hollow like p1 but the centre treble lacks authority and instruments gets a little back...i mean little and you can still distinguish between instruments well in complex track
Spinfit twinblade cp240
Hahahahhahahhahahhahahaha
Image improved drastically, treble became airy and mid bass lost some authority.
Isolation made sound even better
Sounds a little softer allover frequency but man this nailed it
Well now i am thinking of making custom cable myself with my own hard testing...not snake oil and crap.
I will make 4 quad braid of 7N neotech silver litz and then make a quad braid of these braids(total 16 wires)
All wire in parralel will drop resistance by division of 4
This will make impedance drop from wire and some critical damping will be achieved due to 7N silver. Treble will gain authority getting my image even better(song imaging harmonic lies in bass and treble, instrument lies from 100hz to 1.2khz.....and cymbal structure in 4khz). Well litz wire in quad braid will get bass timing perfect.
Will add attenuator circuitry or impedance control to get myself 32ohm critical matching so sound gets well structured and make it balanced 4pin. Will also make adapters
Buahahhahahahahahhahahaha i have legend iem.
JH layla II: still have bigger soundscape than T2 modded, livelier sound. It sounds neutral but vivid in saturation. Its like vibrance more than saturation
Shure se846: the best engineered iem. Just treble is little dull doesnt mean its conservative. Its true response, like what is reality. T2 came close, but dynamic cant match quickness of sonion BA. Bass is very true and textured.
Well remove micropore mod if you love foam.
Sounds very similar to normal tips with micropore but treble tending toward mdr 7550.
Twinblade is unrivalled here.
