Ahmad313
- Jan 23, 2013
great thoughts ,,Hopefully I can get a job this summer so I can get all sorts of IEMs, I hate spending my parents money.
Wait, aren't the T2 simply MMCX?
Didn't realise thatThere are two options on that page. Either 0.78 mm 2 pin or MMCX.
First impression of the KZ ZS5 : looks very promising!
Seems quite close to the T51i. Defenitly a step up if you compare to the very good Einsear T2
Need more time of course. So far very very nice!!
Will up date my impressions in some days
69 dollar TFZ King arrived today. Pretty pleased. The connector prongs could be a little shorter (they stick out a little bit) but it doesn't affect function and they're a little more comfy than I expected (I didn't expect much, as far as comfort). They sound great, and are driven beyond adequately by my phone, which was what I was after. For under 70 dollars (thanks, Black Friday) I think it would be hard to complain too much.
Didn't realise that
Is this cheap cable any good? Need one without mic for the **** UEs
https://www.aliexpress.com/item/KZ-...e-MMCX-Cable-for-Shure-SE535/32821324930.html
That's the exact same cable I use with my UEs. It's a perfect pairing.Didn't realise that
Ok so, I was listening to music when suddenly the left side of the einsear t2 went super quiet. Audio still went through, but it was like 1/10th of the right side's volume.
Since I've had similar issue in the past with xiaomi piston 2 and xiaomi hybrid, I removed the tip and removed the grid with a needle. Now it works perfectly fine. However, I found that the left side was now more clear and a bit louder, so I did the same to the right side and I can definitely notice an improvement in loudness and clarity.
Anyone tried removing the grid of their earbuds in the past? If so, did you notice any change? I'm curious.
In addition to what @Slater shared about materials, I'd just toss this out there: ear wax... can make just cleaning or replacing used screens a huge differenceOk so, I was listening to music when suddenly the left side of the einsear t2 went super quiet. Audio still went through, but it was like 1/10th of the right side's volume.
