drag0nslayer
How would you describe xba sound ? is it worth buying on 11.11?Or the Pioneer CH5T at around half the price of CH9T, I love the Svara Red as well though
Aren't they both are more towards treble ?If you mean the **** XBA 6in1 they are quite close to the TinAudio T2. I like and highly recommend both
@HungryPanda can you compare the CH9T and CH5T?
I like my TinAudio T2, neutral with a pleasant treble signature, not a bass heads iem but goes deep when needed. I have not heard any TFZ iems
CH5T is half the price of CH9T or even less. Sound is a tad better on CH9T as well as a more solid build. Both are good iems
also take a look the f9 Pro , will launch 15th Nov., price is $139 ,Hello, I was wondering if anyone has any info on sub 100eu Chinese IEMs in terms of long term quality/build. I bought a lot of KZs and other cheap ones because I know at least one side will start malfunctionning soon or the cable will be eaten by my bunny.
Often, IEMs reviews factor in the build quality out of the box but has anyone looked into how long the older ones have lasted, or how well they're built on the inside?
Out of the K3 pro, moni one, toneking nine tails, fiio f9, Mee audio P2, tfz kings, pioneer CH9T, I'm starting to lean towards the pioneer only based on reputation alone. Am I wrong?
Hello ! Can you suggest me an earphone with a mostly neutral sound signature but with a slight V ou bassy signature please ? I've heard of the Pioneer CH9T but they are too expensive, i'm searching something around 50$ to replace my Xiaomi Hybrid Quantie Pro.
Thank you !
