Nimweth
My review of the HZ Sound Heart Mirror is now available to read:
https://www.head-fi.org/showcase/hzsound-heart-mirror.24597/reviews
Same here with the SSR...loved the fit, but in the end not enough weight to the music.Yeah that's a possibility, or there's always EQ. But even so, I wasn't a fan of the thin note weight on the SSR, don't think the micropore mod or EQ could fix that.
Anyways the SSR was a loaner and I've returned it. Oh wells.
I'm working on my review as well and I'd say that I agree for the most parts, but maybe try a tip with a long nozzle and that bass will be astonishing. I assume you are using them with Spiral Dot or the stock tips.My review of the HZ Sound Heart Mirror is now available to read:
I am using the stock medium white silicone tips. I will try KZ Starlines which are taller. Thank you for the tip (lol).I'm working on my review as well and I'd say that I agree for the most parts, but maybe try a tip with a long nozzle and that bass will be astonishing. I assume you are using them with Spiral Dot or the stock tips.
They are releasing new 7BA(TRN X7) and I hope it’s a Audio Technica style
The shell looks nice.
ER2E and HeartMirror are very different IEMs, ER2E is a mid-centric flat and weightless sounding monitor IEM to check sounds I grade as Tonality C, technicality B. HeartMirror is bright-harman ish neutral Starfield mock up, tonality B, Technicality B-.Darn I can't decide on the Etymotic ER2SE (which I had before) and the Heart Mirror.
I was dead set on picking up another ER2SE but had second thoughts at the last moment. Both are identical in price, I can pick up the ER2SE locally at Adorama in NYC for $49. The only reason I gave up my previous set was the bullet design.
If Etymotic neutral is upto your preferences then ER2SE is good contender but that deep insertion bullet design is a pain.Darn I can't decide on the Etymotic ER2SE (which I had before) and the Heart Mirror.
Heart Mirror has great technicalities and timbre with a bright neutral signature. For $50 or even $100, not many single DDs pack a punch like them. Overall it's a good package and a durable product.
If you can demo the set locally that would be the best way to make the judgement.
For something different and complimentary you can consider the KBEAR Neon.Recommendations please! I recently ordered Heart Mirror as my first IEM. They haven't even been delivered yet, but I would like to order another set or two with different tunings to compliment them. My budget is $100ish, and I will be listening on IEMagni/Modi3+
They look great and sound profile is interesting. Definitely going into my watchlist. Will be interesting to see how they fare as an overall offering vs FD3/ProI had the privilege to audition the TForce Yuan Li tour unit and this set is a single DD with very good technicalities and authentic timbre. Neutralish bright tuning. I think it is actually an upgrade over the Heart Mirror in technical performance. The Yuan Li needs amping too, it scales very well with amping. It is kind of a mini Tanchjim Oxygen.
My only issue with the Yuan Li was the upper mids are a bit fatiguing and can be shouty on some recordings. This tour unit is not the final tuning though, heard that TForce is damping the upper mids slightly for their final release product, after taking feedback from the first adopters. I really look forward to the final tour unit, was already quite impressed with the prerelease unit.
Maybe you can try Tin T2 Plus if a different version of neutral is what you need. Else in the fun tuning variants you can try KZ DQ6 (mild V shape), Geek Wold GK10 (I have one on the way as well, but impressions are mostly positive so far), and Moondrop Aria (Harman neutral tuning)Recommendations please! I recently ordered Heart Mirror as my first IEM. They haven't even been delivered yet, but I would like to order another set or two with different tunings to compliment them. My budget is $100ish, and I will be listening on IEMagni/Modi3+
