AmericanSpirit
Member of the Trade: Night Oblivion
Acutlaly that video link was bad one,Here you go
[watch out for volume!, turn to zero then raise] embedded video may play with 100% volume from the beginning
Iām adding peaks and dip spots of each IEM on my comparison chart, and also addressing wether the IEM, from my spot standards are āspot hitterā or āconservative spot compensatorā
https://www.head-fi.org/threads/bes...s-sharing-reference-list.805930/post-16336743
This is slower and better visualization
You can find your ear resonance even from sub-bass range, for me itās 96hz.
if you multiply lowest reaonance point (for me 96hz), you can find your upper mid pinna gain range. 96x2x2x2x2x2=3,072hz (pinna gain) x 2 =6,144hx(concha gain) x 2 = third harmonics 12,288hz.
that 6.1khz and 12.3khz dip will reduce ear resonance thus reducing fatigues but other frequency range remained clear so if will not cost huge sacrifice on total presentation.
you surely will find sharp edge anywhere from 5khz-7khz. Neutral gear is recommended for testing.
if you divide that 6k range sharp edge by 2, thats your voice peak (pinna gain)
