The end of this damned year approach,it would be cool if headfier can share their personal favorite 2020 discoveries!
Mine:
IEM:
HZsound Mirror
Hisenior T2U
BQEYZ KC2
BGVP Zero (for vocal)
Moondrop Starfield
Final Audio E1000
KBear KB04
Blon BL-03
FIIO FH3
Dunu DK2001
DAC/AMP:
Topping L30 (bright, detailed open sound with powerfull output small size)
SMSL SH-9
QDELIX 5K (the BTR5 killer)
FIIO BTR5
Tempotec HD PRO (or even better Meizu hifi pro)
Audirect BEAM 2 (too expensive IMO but so powerfull and handy)
DIY ES9280C dongle
Worst IEM:
NiceHCK NX7 mk2 (Gold medal!)
Blon BL-05 (silver medal!)
Dunu DM480
KBear KS2 (Bronze medal!)
Tinhifi T2+
BQEYZ BQ3
My 2020 favourites in the following categories are:
$300 – 500 USD IEM:
LZ A7. Provides a mind boggling 10 tuning configs (or more with aftermarket tuning nozzles). It has excellent technicalities, good fit, good isolation, and the best part that surprised me is that the LZ A7 has very natural timbre for a BA/piezo containing tribid (other than the higher treble frequencies handled by the piezo). Most folks would find an ideal sound signature with it, maybe except diehard bassheads.
$200 – 300 USD:
Audiosense T800. It has good technicalities, is “fun sounding” and excellent isolation nearing 30 dB. Even though it contains a BA bass, it sounds like a DD bass due to a vented subwoofer. The T800 may be a bit on the bright side, so it isn’t the best option for treble sensitive folks, but you can use knowles filters, warm sources or eartips to tame the treble.
$100 – 200 USD tie:
TRI I3. Smooth, balanced, grand and coherent despite the weird 1 planar + 1 BA + 1 DD config. It needs amping though, the planars handling the mids are quite power hungry. It has one of the best soundstages at the $100ish region when amped, with sweet planar mids. Treble is safe, bordering on darkish, so maybe not for trebleheads.
$100 - 200 USD tie
KBEAR BElieve. “Bearly believable” for a full beryllium set at this price? The KBEAR BElieve sports a smooth and refined U shaped tuning, great technical chops in the mids and treble areas for a single DD. It has good timbre for acoustic instruments but is very hard to drive, as per the 98 dB sensitivity. It sounds muddy, congested and slow in the bass with a low powered source, but scales beautifully when optimally amped, so those that don’t intend to get an amp best look elsewhere. With power, the KBEAR BElieve does hit about 70% of the technical performance of the famed DUNU LUNA, at 10% of the price!
Sub $100 USD:
HZSound Heart Mirror. Nice mirror like shells, as per its namesake, it is a neutralish bright set, excellent timbre for acoustic instruments. I like how it manages to get a forward upper mids without going into harsh or shouty territory, a very fine line to balance. The Heart Mirror has good transients and speed on the driver. Note weight is thin and soundstage is not the best though, and it needs amping to shine, sounds meh from a smartphone. Good set for vocal lovers and timbre lovers, but maybe not so all rounded due to the lack of bass, but it takes to EQ in the bass like a champ.
Favourite earbud for the year:
SMABAT ST10S Black Gold. Neutralish set with subbass and upper mids boost. If you have always looked down on earbuds for not having subbass, think again. The SMABAT ST10S Black Gold has the best subass quantity and extension I’ve ever heard in a bud. It has excellent technicalities, is MMCX detachable and can be worn over ears or cable down. It needs amping though, as per the 150 ohm impedance. Not to be mixed up with the SMABAT ST10S Black Silver, which is tuned differently (and has lower impedance).
Best unlucky bag/Fukubukuro/Mystery bag:
Urbanfun YBF-ISS014 – it is extremely exciting to see whether u get a beryllium vs “noble metal” driver. Or a working versus wonky mmcx. Even newer batches of the Urbanfun have been reported to have QC problems in the audio forums.The Urbanfun can be summed up in this statement by Forrest Gump and headfier @lgcubana : “My Mom Always Said Life Was Like A Box Of Urbanfuns. You Never Know What You’re Gonna Get.”
Best price to peformance
TRN golden ears $14,750.00 USD IEM paired with $3400 USD xiaofan ortiz “king of the gods” cable. Mere mortals cannot hope to use these gear if not you’ll be struck down by lightning! I hope the Bellsing BAs inside are also made of gold!
